Activity Forums AJA Video Systems KonaSD NTSC playback issues…
  • KonaSD NTSC playback issues…
    Posted by Paul Harb on August 24, 2005 at 5:29 pm
    Im trying to get my DVCPRO50 timeline to playout of my KonaSD card and it just freezes onthe last frame until I hit stop on the playback bar, then updates the image. Ive looked at the view/all frames and it is checked….any ideas, I had this working before…..
    G4 Dual 1 gig/ FCP 4.5/latest drivers for KonaSD….
    Paul
    Luke Maslen replied 21 years ago 3 Members · 3 Replies
  • Gary Adcock
    August 24, 2005 at 6:38 pm
    [Paul] “m trying to get my DVCPRO50 timeline to playout of my KonaSD card and it just freezes onthe last frame until I hit stop on the playback bar, then updates the image. Ive looked at the view/all frames and it is checked….any ideas, I had this working before…..”
    View -external video is not set properly.
    reset it to your DVCPro 50 easy setup then relaunch FCP– all should be fine.
    Check that you turned have it on!
    gary adcock
    Studio37
    HD and Film Consultation
  • Gary Adcock
    gary adcock
    Studio37
  • Luke Maslen
    August 26, 2005 at 5:46 am
    Hi Paul,
    Gary’s response is probably the answer to your question. Regardless of whether that helps or not, you might like to update to the latest drivers for use with Panther and Final Cut Pro HD 4.5. They are the DeckLink 4.8.1 drivers which we released yesterday and you can download them from the software downloads page. Installing this software will delete your Final Cut Preferences file. Deleting this file is a common remedy for miscellaneous odd occurences in Final Cut Pro so if Gary’s suggestion doesn’t work out, installing the new drivers would be a good next step.
    Regards,
    Luke Maslen
    Blackmagic Design
