Activity › Forums › AJA Video Systems › Kona/IO swapping
  • Kona/IO swapping
    Posted by Tim Phillips on January 16, 2006 at 9:05 pm
    Hi All
    I’m just about to do final set-up on my new FCP 5 system. I’ve purchased Medea FCR2X drives and will be using an AJA IO box for input.
    A buddy of mine is getting a new system later this month also with FCP 5 and either a Kona 2 or 3, depending on which Mac he ends up with.
    Will I be able to use his digitized HD clips on my system? When he’s busy he’d like to digitize raw tapes through his Kona card, put the files on a/several firewire drives, and bring them to me to make rough cuts.
    Will this process work? Can I use HD files even though I don’t have an HD capture card?
    Tim
    Fred Connors jr. replied 20 years, 8 months ago 2 Members · 1 Reply
  • Fred Connors jr.
    January 17, 2006 at 1:08 am
    SD files will be fine.
    How will you play back HD files without and HD card, other than just on your FCP canvas?
    Fred
    The Troupe – Modern Media Design & Production
