Activity Forums AJA Video Systems Kona3 overmodulated audio -Help-
  • Kona3 overmodulated audio -Help-
    Posted by Tim Langston on April 8, 2006 at 6:11 pm
    OK, I’ve just installed the Kona3 on my G5 Quad. I’m having problems with audio levels, they look fine but it sounds overmodulated. I’ve tried adjusting sound in system prefs, but that just lowers the levels. I’m beginning to think it’s my Tascam DM-24. Any suggestions would be great. I’m in the state of panic so I’m not thinking clearly.
    tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
    Tim Langston replied 20 years, 5 months ago 2 Members · 4 Replies
  • Tim Langston
    April 8, 2006 at 6:31 pm
    OK, something else I just found. The Analog RCA’s out of the K3-Box sound fine.
    Tim Langston
    Fort Wayne, IN
  • Bob Zelin
    April 8, 2006 at 7:56 pm
    you are not describing your problem properly, so you are panic’ed. Is this existing audio, or do you get the distortion when you digitize into the Kona ? Are you using SDI embedded audio, or AES audio ? What is the source VTR? If it is a VTR, why are you going thru your mixer – why not just take the SDI or HDSDI out of the VTR, and go directly into the Kona 3 using the embedded audio. do this, and monitor off the RCA outputs (which I bet sound clean). Then monitor thru your Tascam AES inputs – does it distort here ?
    Without more details, no one can help you.
    bob zelin
  • Tim Langston
    April 8, 2006 at 8:18 pm
    Sorry, here’s more…..
    This is coming from existing audio, like FCP’s tone, to aiff files that voice people have cut for me. The voice files have been copied from my CineWave system. Currently I’m using only BetaSP, so no capture from the deck just yet.
    I’ve checked the Kona’s output gain and have tried changing from 20% to 70%, sure the volume changes but not the distortion. I’m starting to think it’s something on the Tascam DM-24.
    And like you said Bob, the RCA output is fine.
    More testing tomorrow.
    Tim
    Tim Langston
    Fort Wayne, IN
  • Tim Langston
    April 13, 2006 at 9:06 pm
    Well to make a long story short, the Tascam DM-24’s clock was set on 44.1 not 48. I changed it but must not have stored it. I stored it this time and all’s fine. What an audio board, menu after menu after menu. (not that I’m complaining).
    Tim
    Tim Langston
    Fort Wayne, IN
