Activity › Forums › AJA Video Systems › Kona3 – Frame Playback Offset tips?
  • Kona3 – Frame Playback Offset tips?
    Posted by Dave Gorrie on April 9, 2009 at 10:30 pm
    Hi All,
    We just upgraded to a Kona3 (from an LHe) and are having different Playback offsets then we previously did. Is there a general rule for these offsets, or is it really dependent on our decks/procs/signal flow? The LHe seemed to do fine with no playback offset on all the old layoffs (SD/HD Sony decks mosty). I found that laying off to our SRW5500 required +1, and an SD downconvert to our Digi (DVW-M2000) needed +2 with the Kona3.
    We currently run everything SDI (embedded audio), simple patch bay from rooms->decks, legalizer (Harris DL860) and that’s about it. Our Avids don’t seem to get a throughput delay from the Harris, so I didn’t think that was the issue…but maybe FCP is dealing with it differently?
    Just thought I would check, I think I’ve got most of the decks figured out, but just wasn’t sure if there was a rule of thumb for offsets (i.e. when downconverting, always add +1 on layback, or SD is always 0, stuff like that?) – and I figured this is the place folks would know!
    Thanks in advance,
    Dave
    Dave Gorrie replied 17 years, 5 months ago 2 Members · 2 Replies
  • Gary Adcock
    April 11, 2009 at 1:46 pm
    [Dave Gorrie] “Just thought I would check, I think I’ve got most of the decks figured out, but just wasn’t sure if there was a rule of thumb for offsets (i.e. when downconverting, always add +1 on layback, or SD is always 0, stuff like that?)”
    Dave
    I do not see different offsets between cards. I have always had differing offsets for decks.
    +2 for an SRW5500 is the same as mine- but I have it set to +1 for the SRW1c (60p) deck and for the -1 for SRW 5800 so go figure. these are the same in dual link as single link and the same on my k3 vs LHe.
    FYI- the kona conversion offset is ALWAYS 1 Frame – up/ cross/ down all are unified into the minimum delay possible and because most of those consist of field to frame conversion the delay is 1 frame no matter which frame rate you are passing thru and a one frame delay is considered realtime by SMPTE.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Dave Gorrie
    April 11, 2009 at 3:21 pm
    Hey Gary,
    Thanks for the insight! I kind of thought it was a little bit of trial and error based on decks, but just wanted to make sure it wasn’t uh…”user error” – because that never happens!!!!
    It’s been a while since we’ve done such heavy outputs in FCP so jumping back into the fire so quickly is always fun!
    Thanks again,
    Dave
