Activity Forums Apple Final Cut Pro Legacy Kona2 RS-422 Control and Sony XDCAM PDW-1500
  • Kona2 RS-422 Control and Sony XDCAM PDW-1500
    Posted by Mark Maness on October 31, 2005 at 5:16 pm
    Has anybody gotten this machine to work with the Kona2 RS-422 port? I have gotten it to work only a couple of times and then it will loose connection throughout the batch digitize process. I’m using FCP 5.03 (didn’t work in previous versions of FCP 5.0 either). I have the Device Control set to AJA Kona2: 29.97 Sony VTR. That is what my video settings are so I have set it to that standard. I don’t get it at all. I have to use the firewire for machine control but I’d rather use the RS-422 for better frame accuracy when searching and cueing up a shot. Can anybody help me?
    _______________________________
    Wayne Carey
    Schazam Productions
    Michael Buday replied 20 years, 11 months ago 3 Members · 2 Replies
  • Gary Adcock
    October 31, 2005 at 5:37 pm
    Wayne
    it seems that everyone is having problems with that deck
    https://www.avid.com/onlinesupport/supportcontent.asp?productID=114&contentID=8170&browse=
    Avid says you can only do it over FW.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Michael Buday
    October 31, 2005 at 6:16 pm
    “it seems that everyone is having problems with that deck”
    I’ve used this deck many times via RS-422, ethernet and Firewire, and they all work fine, but RS-422 control is limited to capturing from SDI or analog only – you cannot capture via Firewire while under RS-422 control.
    If you’re attempting to capture via Firewire under RS-422, I would change your setup to capture via the SDI port using whatever codec you need for your project within FCP.
    All the best,
    Michael Buday
