Activity Forums AJA Video Systems KONA2 Playback offset
  • KONA2 Playback offset
    Posted by David Battistella on August 27, 2005 at 7:08 pm
    I know that some of us know that FCP ships with the playback offset to 4 frames. Should this be the offset when working with the KONA 2. I am hoping that it is a zero offset but does anyone know what the Playback offset should be when working witht the KONA 2?
    Please note I am talking about
    Sequence settings>Playback Control>Frame Offset
    This defaults to 4 frames but with my other capture board should be set to 0.
    Thanks in Advance.
    David
    Walter Biscardi replied 21 years ago 4 Members · 4 Replies
  • Jerry Hofmann
    August 28, 2005 at 1:24 pm
    That might differ somewhat from machine to machine, but figure that if external audio and video is in sync, you leave it alone… right?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Aja Sales department
    August 28, 2005 at 3:20 pm
    Hi David-
    This setting for Kona 2 (and Kona LS) should be “0”.
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • David Battistella
    August 28, 2005 at 3:31 pm
    Gerry,
    I believe this feature was introduced in FCP to compensate for he lag in AV between the canvas and the output monitor. With other AJA products like the I/o this ca be set to as much as 7 frames to compensate for the differenc of what you are seeing in teh canvas and the broadcast monitor.
    David
  • Walter Biscardi
    August 28, 2005 at 5:55 pm
    [David Battistella] “Sequence settings>Playback Control>Frame Offset”
    Set it to 0 for Kona 2 use.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
