Activity › Forums › AJA Video Systems › Kona2 machine control
Posted by Mark Maness on September 1, 2005 at 5:18 pmI have had this Kona2 for three months now and I have never been able to get the RS-422 machine control to work at all. Its not been a real problem yet since my machine can use Firewire for control. I have tried everything possible. I have even made sure that my deck has working control. The machine will work just fine on an AJA IO but not on this Kona2. I even tried to change cables. No good. HELP!
_______________________________
Wayne Carey
Schazam ProductionsMark Maness replied 21 years ago 6 Members · 10 Replies -
Gary Adcock
September 1, 2005 at 5:33 pm[Wayne Carey] “I have had this Kona2 for three months now and I have never been able to get the RS-422 machine control to work at all.”
WHAT DECK?
are you sure it has rs422 or rs232
what have you tried?
what other decks have you tried?
have you called tech support?gary adcock
Studio37
HD and Film Consultation -
Mark Maness
September 1, 2005 at 6:45 pmI’m using a PDW-1500 XDCAM machine. Yes, it works on the AJA IO but no I have not been able to hook up another machine to the Kona2. The only other machine I have is a Sony UVW-1800 that is wired into a rack so removing it is no small task. I’ve tried changing cables, I’ve hooked up the machine to and AJA IO (which it works just fine), and I looked to see if there was a setting in the Kona2 Control Panel – nada!
And yes, to answer the next question. I have made sure that the machine is in its 9-pin RS-422 mode instead of i-Link. No, I haven’t tried tech support yet because they are slow to respond and I figured somebody out there might have seen this with all the expertise that is available here.Like I said before, its not keeping me from working but its annoying to keep switching the machine from 9-pin to i-Link mode. Well, that is until we get a HDCAM machine sometime in the near future.
Wayne Carey
Schazam Productions -
Gary Adcock
September 1, 2005 at 7:17 pmWayne
have you check the deck to know the 422 is working? ( try slaving it to the beta deck)
and I would give tech support a call, it usually only takes a couple of hours at most for them to get back to you.
there are only so many tech guys at AJA.gary adcock
Studio37
Fred Connors jr.
September 1, 2005 at 8:30 pmI with Gary, tech support gets back to me within a few hours at most.
But first what device control presets have you chosen?
I have found that when we are using Firewire to control the deck we somtimes forget to reset the device control and protocol.
Fred
Bob Zelin
September 1, 2005 at 11:57 pmWayne –
I ASSUME that you manually went into the Audio/Video Setting, and looked at the 4th tab – the VTR control settings, and made sure that Kona 2 RS422 was checked. As you probably know, in this menu, you can be using the Kona 2, and change where your VTR control comes from – you can select the AJA I/O, you can select Firewire, you can select a damn Keyspan adaptor if you set it up in the menus. I hope you are not assuming that it automatically starts to work. PLEASE confirm with us that you have checked your menu’s in the Audio/Video setting, and that Kona 2 RS422 has a check mark next to it.Bob Zelin
Tony
September 2, 2005 at 7:52 amWayne,
The tech support at AJA has never been slow to respond to any of my needs. I generally have always been able to speak directly to Rudy and/or Clark for over the phone support.
Considering my personal experience dealing with the poor quality of tech support from other companies I consider AJA tech support to be the peak of customer service.
Tony Salgado
Mark Maness
September 2, 2005 at 1:27 pmOk, guys… I talked with AJA tech support and I did get a response. I reseated the Kona2 card and reseated the cables to the K-Box. Now, everything seems to work. I guess I just had a little gremlin stuck in the card somewhere. As for the tech support, yeah, this time they came through but I have stumped them on the audio crackle problem that I am having. The only thing that I could wish for now is HDV support from AJA. Apple’s version has somtething to be desired.
Thanks guys for all of the responses! You’ve been a big help once again!
Wayne Carey
Walter Biscardi
September 2, 2005 at 1:51 pm[Wayne Carey] “As for the tech support, yeah, this time they came through but I have stumped them on the audio crackle problem that I am having”
Audio crackle was addressed in another thread here. It’s releated to your Ref In setting.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
Bob Zelin
September 2, 2005 at 10:33 pmWalter is correct – go into your Kona control panel – bet it’s in Video In, instead of Free Run, or External Ref. The crackle goes away when you get it off Video In.
bob Zelin
Mark Maness
September 6, 2005 at 1:53 pmYeah… that’s what I’ve heard but my ref is already set to Free Run and I still get the audio crackle every once in a while.
Wayne Carey
Schazam Productions
