Activity › Forums › AJA Video Systems › Kona2, Kona3 and Final Cut Pro
  • Kona2, Kona3 and Final Cut Pro
    Posted by Mobyzipper on March 26, 2007 at 1:37 pm
    We encoded the same clip as Uncompressed 8-bit, Uncompressed 10-bit. (Kona Default Settings) From NTSC Digibeta
    Kona_8bit_Original_FCP_Encode.mov
    Kona_8bit_Encode_Exported_10bit.mov
    Kona_8bit_Encode_Exported_8bit.mov
    Kona_8bit_Encode_Exported_None.mov
    Kona_10bit_Original_FCP_Encode.mov
    Kona_10bit_Encode_Exported_10bit.mov
    Kona_10bit_Encode_Exported_8bit.mov
    Kona_10bit_Encode_Exported_None.mov
    All 8 files were compared again the original Falme version.
    All files had a color shift. Even NTSC Colorbars had a shift. Why is that?
    Does anybody know about the Kona cards yuv-rgb converion?
    Is there a way to maintain the color without it shifting?
    Considering BlackMagic Card……..
    Jeremy Garchow replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    March 26, 2007 at 2:57 pm
    If you need an RGB codec, have you considered capturing to AJAs 10 bit RGB codec and then telling FCP to render in RGB? Perhaps this will help you. You will find the same problem with a Blackmagic card as they use the exact same codecs that AJA does, and those codecs are Apple’s. What you are seeing is the YUV to RGB color space ‘shift’, you need to either correct it in FCP before export, or correct for it in Flame if it’s possible. I don’t know Flame’s color correcting capabilities.
    Jeremy
