Activity Forums AJA Video Systems Kona2 & FW Tascam control surface
  • Kona2 & FW Tascam control surface
    Posted by Ken Ecker on November 18, 2005 at 1:28 am
    I’ve been using a Kona2 & KBox for the last month and loving it. However, I’ve been using a Tascam FW1082 control surface – i/o to monitor audio. Because “audio follows video” I should use the Kona2 for the audio output. However, the Kona is AES, and the Tascam is SPDIF (coax), so I ordered an AES/coax converter (Hosa CDL-313). After resetting all my audio outputs/pref’s in FCP (and Audio Midi/Device setup) to Kona2, I’m getting nothing. ‘lil help?
    Thanks.
    Ron Thompson replied 20 years, 9 months ago 3 Members · 5 Replies
  • Ken Ecker
    November 18, 2005 at 1:49 am
    Figured it out. The Tascam unit needs to act as a slave (Monitor/mix mode) before it can return to controlling and monitoring, through the Kona2. It still seems a bit ‘lucky’, but if the settings are proper, and the sound is doing what it’s supposed to…
    Thanks anyway.
  • Richard Dee
    November 18, 2005 at 7:23 pm
    I use the tascam FW1884 and really like it. However the jog control of the Mackie was far superior- the tascam doesnt like jogging single frames.
  • Ken Ecker
    November 18, 2005 at 11:14 pm
    I totall agree. I use a contour shuttle pro for jogging.
  • Richard Dee
    November 19, 2005 at 12:13 pm
    I have the shuttle pro as well. All I can say is that the Mackie was so much better than the shuttlepro.
  • Ron Thompson
    November 19, 2005 at 7:56 pm
    I’ll second that. The Mackie plays very well with FCP…and mixing shows is SO much easier with it. I’m glad I didn’t spend the money on a shuttle pro. Mackie’s transport controls are great.
    I just wish Apple would open up more functionality with the MCU…plug in parameter control, etc. Hopefully in future updates.
