Activity Forums AJA Video Systems Kona2 capture offset
  • Kona2 capture offset
    Posted by Craig Ernst on August 2, 2005 at 6:31 pm
    I use a Kona 2 with K-box and all Kona recommended hardware and software. Is there a “capture off set” I need to be concerned with while using drivers 1.1.2. I usually use Easy setups for 8bit HDCAM
    Craig
    Scimmy replied 21 years, 1 month ago 3 Members · 2 Replies
  • Gary Adcock
    August 3, 2005 at 2:01 pm
    [Craig Ernst] “use a Kona 2 with K-box and all Kona recommended hardware and software. Is there a “capture off set” I need to be concerned with while using drivers 1.1.2. “
    the Capture Offset in FCP is in
    AV settings > Device Control Presets
    there is not a separate place for the Kona 2
    gary adcock
    Studio37
    HD and Film Consultation
  • Scimmy
    August 11, 2005 at 8:26 am
    Yo C’rr. Get a job will ya. TS
