Activity › Forums › AJA Video Systems › Kona2 and KonaLH differences?
Posted by Greg Jones on September 14, 2005 at 1:43 pmKona just announced the Kona LH. After reading the specs I’m trying to figure out what the differences between the two cards really are. The literature on the website says ‘The Kona LH has some of the features of the Kona2 and AJA Io’. Can anyone out there enlighten me?
Greg Jones
D7,Inc.
Orlando,Fl.Gary Adcock replied 21 years ago 6 Members · 6 Replies -
Walter Biscardi
September 14, 2005 at 2:02 pmThere’s been a couple of threads on this down below.
Basic differences are No Up-Convert or Dual Link HD on the LH.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
Jeremy Garchow
September 14, 2005 at 3:38 pmDon’t forget the analog SD and HD INPUTS on the LH and not on the Kona2. These are also significant changes.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Bob Zelin
September 14, 2005 at 10:53 pmGreg –
be happy. You already own the Kona 2 and the AJA I/O. You have everything. When you need to bring your second I/O room HD, you will still purchase a Kona 2 – just like you have – to be complete.If you were starting from scratch, the combo of the I/O and Kona 2 is still unbeatable. Kona LH is a more “entry level” system that does everything. AJA is playing “keeping up with the Blackmagic’s” on the low end. (not that the LH is a low end card !).
Bob Zelin
Sam Zimman
September 15, 2005 at 4:35 pmI think the price difference is only $400. Right?
Also, please correct me if I’m wrong, but to edit dual-link HD you would need two fully populated xraids (each side striped RAID5 and then all 4 of them striped RAID0 together) and two fiber-channel cards (thus splitting the signal over 4 fiberchannel cables). And the only tape formats that support dual-link HD are HDCAM SR and D6 Voodoo.
You can still always do a software upconvert in the FCP timeline or with Compressor.
Walter Biscardi
September 16, 2005 at 2:21 am[Sam] “Also, please correct me if I’m wrong, but to edit dual-link HD you would need two fully populated xraids (each side striped RAID5 and then all 4 of them striped RAID0 together) and two fiber-channel cards (thus splitting the signal over 4 fiberchannel cables).”
I wouldn’t go XRAID at all, waste of money. Go with Medea and it’s a lot less money to get the throughput necessary for 4:4:4 Dual Link. We’re about to set up a Dual Link system for a film transfer facility here in Atlanta. I’ll try to remember to let you know how we set up the RAID for it.
Gary Adcock
September 16, 2005 at 3:23 pm[Walter Biscardi] “I wouldn’t go XRAID at all, waste of money. Go with Medea and it’s a lot less money to get the throughput necessary for 4:4:4 Dual Link. We’re about to set up a Dual Link system for a film transfer facility here in Atlanta. I’ll try to remember to let you know how we set up the RAID for it.”
Actually at 1080p24 can be done on a single fibre array the data rate peaks at about 200mgs a second.
Huge offers the 4210 array that does 4g fibre and can capture / playback at 320mgs a second.the buggy celerity driver however is needed to get 4g.
From IBC
Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL
