Activity Forums Blackmagic Design Kona SD – Decklink 6.6.2 – Mac OS X Leopard 10.5
  • Kona SD – Decklink 6.6.2 – Mac OS X Leopard 10.5
    Posted by Christoph Preller on January 14, 2008 at 1:18 pm
    I ‘ve to PowerMac G5 with a Kona SD Card. I am planing to Upgrade to Final Cut Pro 6 and Mac OS X Leopard 10.5.
    This configuration is not mentioned in the “Where are the Blackmagic Kona SD and Kona HD drivers?” Document. Since the driver are incorporated in the standard DeckLink drivers and the DeckLink Drivers will work with FCP6 and 10.5, I am assuming that this configuration will work as well.
    Am I’m right?
    has anyone tried this configuration before?
    Kind Regards
    Christoph
    Christoph Preller replied 17 years, 3 months ago 3 Members · 3 Replies
  • Steven Kochones
    January 17, 2008 at 4:07 am
    I also want to know if BM drivers will work with a Kona SD and FCP 6. In my case, I’m using Tiger. I have installed different versions of the BM drivers but none gives me perfect results. Even though the card is recognized, it doesn’t work all that well. The main problem is a delay when capturing and outputting video.
    If anyone can chime in on this (Luke?) it would be appreciated.
    Steven Kochones
    Arclight Productions
    Hollywood, California
  • Jim Miller
    June 20, 2009 at 1:45 am
    Hello,
    I am about to do the Leopard upgrade also with a similar Kona SD card system. Was your upgrade a success?
    Jim
  • Christoph Preller
    June 22, 2009 at 8:56 am
    Hi Jim,
    I had no luck, I tried different drivers… finally I bought a new AJA video card
    regards
    Christoph
