Activity Forums Blackmagic Design Kona SD and DeckLink 5.4 Drivers
  • Kona SD and DeckLink 5.4 Drivers
    Posted by Brent Altomare on January 27, 2006 at 10:45 am
    Searchnig the forums, it appears that with a Dual 1.8 G5, Kona SD card, OSX 10.4.4, FCP 5.0.4, QuickTime 7.0.4, and the Decklink 5.4 drivers I should be a happy camper, yes?
    Unfortunately FCP does not recognize my KonaSD (says the device is [Missing] in the Audio Video settings). I have tried reinstalling the Decklink drivers after using Uninstall Blackmagic DeckLink to remove anything that may be lurking.
    Card was working before I made my major upgrade to Tiger, FVP5, etc.
    I did run Disk Utility to repair my permissions.
    Any helpful hints? From what I can tell this “just works” for everyone else (with one or 2 notes of needing to do a driver reinstall)
    Brent Altomare
    Groovy Like a Movie
    (877) 3-GROOVY
    Fred Connors jr. replied 20 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bill Kimzey
    January 31, 2006 at 8:45 pm
    It appears not to work for my Kona SD card as well, with the same symptoms you describe.
    Desktop does appear on the monitor, but no option to output video; the Blackmagic Preferences are all grayed out as well.
    Any Kona SD user have this working?
  • Kristian Lam
    February 1, 2006 at 6:56 am
    Hi guys,
    Please revert back to the last driver you had installed while we investigate this.
    regards
    Kristian
    Blackmagic Design
  • Brent Altomare
    February 1, 2006 at 3:57 pm
    Thanks for looking into thie issue, Kristian.
    Are previous versions of the driver available on Blackmagic’s site? And will those previous versions work with Tiger?
    Brent Altomare
    Groovy Like a Movie
    (877) 3-GROOVY
  • Fred Connors jr.
    February 2, 2006 at 5:19 pm
    Same problem with After Effects….
    Fred
  • Fred Connors jr.
    February 3, 2006 at 2:13 pm
    Kristain
    Help…
    What driver do we revert to? 5.2.4 does not work either
    Fred
    G5 KONA-SD, QT 7.01-4, AfterEffects7, FCP 5.x
  • Sean Lander
    February 8, 2006 at 11:49 pm
    More information for you. We’ve been running Kona 1s on a G5 2 gig and a G4 Dual 1.25 for a while now. (Waiting for the intel Macs with PCIe before we upgrade) All Blackmagic driver have worked perfectly. Until 5.4. When installing 5.4 you still get a line monitor out put but FCP won’t see it. Reverting back to 5.2.4 solves the problem. Though you must uninstall the 5.4 drivers first. Both of these systems are running Tiger 5.4.4 and FCP 5.04. We have been on Tiger for quite some time so it’s not related to that.
  • Fred Connors jr.
    February 9, 2006 at 5:36 pm
    Sean
    Yes, I too can cimfirm that if you install 5.4, do not uninstall 5.4, then Custom install 5.2.4 and select all items to install, it works… Both After Effects and FCP.
    Fred
