Activity › Forums › AJA Video Systems › Kona SD 10 Bit RGB issue
  • Kona SD 10 Bit RGB issue
    Posted by Hoop Dreams on July 17, 2006 at 7:46 pm
    Hello,
    I am running Tiger 10.4.7, FCP 5.1.1, Quicktime 7.1, Decklink 5.6 drivers with Kona SD card. my issue is I am unable to layback or play to the digibata using 10 bit RGB. it will play for about 4 seconds then freeze. I tried laying back with photo – jpeg and had no problems.
    Thanks in advance, Ian
    Steve Covello replied 20 years, 2 months ago 4 Members · 6 Replies
  • Gary Adcock
    July 17, 2006 at 9:30 pm
    [Ian Cranston] ” I am unable to layback or play to the digibata using 10 bit RGB. it will play for about 4 seconds then freeze. I tried laying back with photo – jpeg and had no problems.”
    your drives are not fast enough.
    10bit SD needs an array to playback in real time == the data rate is over 30 mgs a second.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
  • Hoop Dreams
    July 17, 2006 at 9:58 pm
    I have an array I forgot to mention its data rate is about 273 MB/s. I was able to playback and layback using FCP 4.5, but after I upgraded to FCP 5.1.1. it stoped. any other thoughts would be greatly appreciated.
  • Bob Zelin
    July 17, 2006 at 10:31 pm
    You have a Kona SD card ??????? Then you have an old system, and probably an old drive array. I bet you have not updated the firmware of your drive array recently (like the Apple XServe RAID) – see the AJA support site for the link to the Apple Xserve RAID firmware update to resolve this issue -if you have a HUGE or Medea array, contact these companies for the update for your OS.
    Bob Zelin
  • Hoop Dreams
    July 17, 2006 at 11:11 pm
    I am running the lastest update…any other suggestions??
  • Bob Zelin
    July 18, 2006 at 12:19 am
    you are running the latest update of what? I am not talking about the latest update of your MAC OS. What drive array do you have, and what firmware version is it running ?
    Bob Zelin
  • Steve Covello
    July 18, 2006 at 7:03 pm
    10-bit RGB? NTSC is not an RGB format, it is YUV/Component or Composite. I don’t remember the old Easy Setups from that card, but shouldn’t there be a SMPTE NTSC 10-bit setup? I figured RGB settings were for 4:4:4 footage coming from HDCam-SR or from graphics files. If this is the case, and your sequence is also set as an RGB sequence, you are demanding more from the system than simply a SD signal. Since I can’t see your settings, I don’t know if this is relevant, but no one else in this thread has mentioned it.
    Steve Covello
    double wide post
