Activity Forums Apple Final Cut Pro Legacy Kona ProRes or Apple Pro Res
  • Kona ProRes or Apple Pro Res
    Posted by Mpigott on August 21, 2008 at 4:32 pm
    I am outputting from a 1440×1080 23.976fps XDCAM timeline and I was wondering which of
    the following ProRes Outputs would better suit my needs
    The first is (from Create QT Movie, Self-Contained) Apple ProRes 1440×1080 24p
    or Kona 2 ProRes 1440×1080 23.976fps.
    Looking at the Apple it says 24p, and I have no idea whether they mean 23.976 or true 24fps
    But looking at the Kona2 choice it says 23.976
    As the Kona totally says the frame rate matches; and the Apple one is vague
    shouldn’t I choose the kona selection
    Gary Adcock replied 18 years ago 2 Members · 4 Replies
  • Mpigott
    August 21, 2008 at 5:19 pm
    To answer my own question; the Apple codec 24 is really 23.976 according to Compressor;
    so I will use this
  • Gary Adcock
    August 22, 2008 at 3:21 pm
    [mark pigott] “Looking at the Apple it says 24p, and I have no idea whether they mean 23.976 or true 24fps
    mark….
    Video is not shot at 24.0 it is shot at 23.976 (rounded to 23.98 by everything BUT AfterEffects)
    FYI your camera shoots PsF in 1080 not P. The True P is only in the 720 format
    ( do a search in the FCP forum for P vs PsF if it matters to you)
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Mpigott
    August 22, 2008 at 3:50 pm
    Ok, so the XDCAM is actually psf and not p then.
    When I import my footage into FCP from the Sony “teleporter”
    (my name, it is actually the transfer software)
    and drop it onto an XDCAM 23.976 timeline the video color code is
    grey (no-render required)
    But should I really be porting my footage to this codec (due to the
    long GOP)
    Other codecs I can try are Apple Pro-Res 24p or the Kona Pro-Res 24p.
    Are these codecs actually frame compatible with XDCAM, and if not
    what codec should I use in FCP?
    Thanks for your help
  • Gary Adcock
    August 22, 2008 at 6:58 pm
    [mark pigott] “Ok, so the XDCAM is actually psf and not p then.”
    all Sony 1080 is PsF, as 1080 all you will see from Canon, Panasonic and JVC, Grass valley and Ikegami
    [mark pigott] “Are these codecs actually frame compatible with XDCAM, and if not
    what codec should I use in FCP?”
    Codec’s have nothing to do with frame rates, the XDcam + Ex formats play fine with FCP, ProRes conversions will give you fast editing and layoff to tape or DVD files since that codec plays in realtime
    while all of the Mpeg based codecs require re-rendering and conforming to create viable Mpeg streams.
    you will be fine –
    and I wish more people put this much thought into shooting.
    gary adcock
    Studio37
