Activity › Forums › AJA Video Systems › Kona output to Grade 1 monitor
  • Kona output to Grade 1 monitor
    Posted by Paul Trainor on September 30, 2011 at 2:27 pm
    Hi all,
    We have in the past used a Barco CRT monitor to view SD output for broadcast to see the true interlaced image. Nowadays for HD we go through an AJA SDI to HD converter and straight to a domestic HD 1080p monitor. This gives us some guidance but we need to view the pure HD interlaced output so that we can check on issues like field priority for final broadcast material. Note: we work with both NTSC & PAL outputs.
    Any help/advice would be gratefully appreciated, even if it is only the name of a suitable inexpensive grade 1 HD monitor which might fit the bill.
    Cheers,
    Paul
    Paul Trainor
    Trainor Davies Design
    Shane Ross replied 15 years ago 4 Members · 3 Replies
