KONA LS SDI Input not working
I’m trying to capture an SDI input in PAL. I’ve only got the SDI Input connected and although I get a signal coming through the scan rate/picture is jumping all over the place. You can view the settings I’m using at
https://www.pushbutton.tv/sdi/index.htm
Can I capture SDI with video only or do I need to connect up the audio as well?
Any help would be very much appreciated.
