Activity Forums AJA Video Systems Kona LS can work without PCI-X ?
  • Kona LS can work without PCI-X ?
    Posted by Melvin Chong on December 13, 2005 at 11:07 am
    Just read on AJA website that no mention of PCI-X slots is needed for the LS. Can anyone confirm that it will work well on G5s without PCI-X slots ?
    Cheers !
    Benrico replied 20 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    December 13, 2005 at 3:51 pm
    [Darth Mel] “Just read on AJA website that no mention of PCI-X slots is needed for the LS. Can anyone confirm that it will work well on G5s without PCI-X slots”
    Yes
    the LS {SD only} board will run in a standard PCI 66 slot. -mine currently runs in a DP G4
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Bob Zelin
    December 14, 2005 at 4:14 am
    as a matter of fact, if you have an ATTO UL4D (for example), you SHOULD put the UL4D in the PCI-X slot and put the Kona LS in the standard PCI slots (2 or 3).
    Bob Zelin
  • Melvin Chong
    December 14, 2005 at 8:01 am
    I’m sorry but I don’t get you. The G5 has no PCI-X slot at all.
  • Melvin Chong
    I’m sorry but I don’t get you. The customer’s G5 has no PCI-X slot at all.
  • Bob Zelin
    December 14, 2005 at 9:21 pm
    Hi Darth Vadar –
    on the current MAC G5’s, slot 2 and 3 are PCI slots and slot 4 is the PCI-X 133MHz slot.
    Bob Zelin
  • Jerry Miles
    December 15, 2005 at 1:30 am
    Hey Darth,
    G4 machines have 33MHz PCI slots
    G5’s with 4 RAM slots have 33MHz PCI slots
    G5’s with 8 RAM slots have PCI-X slots
    Slot 4 = 133MHz PCI-X
    Slot 2 and 3 are 100MHz PCI-X
    The import thing to remember is slots 2 and 3 share a controller and if you put a 33MHz card in Slot 2 that will drop Slot 3 to 33MHz too. This is where you run into issues. Most Firewire cards are 33MHz PCI and some sounds cards so just beware of those situations where you might combine cards in those slots.
    The KONA products just ROCK!
    Jerry Miles
    Mac Products Manager
    ProMax Systems, Inc.
  • Benrico
    January 10, 2006 at 12:46 pm
    “G5’s with 4 RAM slots have 33MHz PCI slots”
    I’m running a 2x2Ghz w/PCI slots and willing to know if it’s true that Kona LS will work fine with this setup ?
    I bought a Decklink SP which simply doesn’t do its job because of a PowerMac firmware that cause the board not to work at all.
    I’d like to know if this Aja board designed to works on G4 PCI also works on G5 PCI ?
