Activity › Forums › Adobe Premiere Pro › Kona Lhi Output Question?
  • Kona Lhi Output Question?
    Posted by Peter Tours on October 13, 2011 at 7:43 pm
    FCP guy here, moving to PP CS5. Got my Kona Lhi going today with PP but only HDMI. When using the Kona with it’s control panel, I get analog component and HDMI, as I do in FCP, but when I switch from the control panel to PP, only HDMI works as the seondary output changes to the same as the primary.
    Anyone know what I can do in PP to make it not do that?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to infinity and beyond!
    Peter Tours replied 14 years, 10 months ago 2 Members · 2 Replies
  • Jim Wiseman
    November 20, 2011 at 6:06 pm
    First you must be an AJA timeline. Go to Sequence/Sequence Settings/Playback Settings. The AJA control panel within Premiere will pop up. There are settings for analog out. Set the Secondary Format to the proper setting, then set the Analog Out to its desired setting. The Primary format is preset by the AJA timeline you choose when you set up originally.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.0 and 5.5, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
  • Peter Tours
    November 20, 2011 at 6:10 pm
    Thanks, I will try that. AJA gave up trying.
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
