Activity › Forums › AJA Video Systems › Kona LHi and Xbox 360 HDMI audio issue
  • Gary Adcock
    February 5, 2010 at 6:23 pm
    [Aaron Pulicano] “I do not own the Xena LHi card yet (still thinking about it), so I can not tell you the available options on the Kona control panel. “
    The LHi and all capture cards are essentially designed for capturing for broadcast and they are not graphics cards, as I said the default of the card is to capture as SMPTE since the Kona’s are designed to acquire and playback video content in a broadcast environment.
    While your google search is interesting,those were not my findings in a test last year.
    I tested for myself as I find info on the net is often less than accurate.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Aaron Pulicano
    February 6, 2010 at 8:11 pm
    What were you findings during your tests?
    And what hardware did you use to determine it?
  • Gary Adcock
    February 7, 2010 at 6:49 pm
    [Aaron Pulicano] “What were you findings during your tests?
    And what hardware did you use to determine it? “
    As I said in this post
    https://forums.creativecow.net/readpost/98/875869
    My tests using Leader and Tektronix scopes do not show a full range signal from WII or PS3, IMHO I doubt your Xbox is different.
    Look Aaron, working in full range is not something you want to do when working in video its not designed for it- in the video space working in “full range” is full of issues. The only time I work in full range content is from DPX files converted from35 Film Scans- I do not capture or work in full range content when working with video formats.
    gary adcock
    Studio37
    Chicago, IL
  • Aaron Pulicano
    February 7, 2010 at 7:51 pm
    Ah, sorry, forgot about your other post. Well, one would expect Wii not to output full range as it is a analog console. As for PS3/360, you need to set them to output full range before they will, as their default settings are both set to “limited” range. Again, though, I do believe their games are nativity done in full range though. But if one should capture them as such is another story I guess.
    Was hoping Arthur would reply about some of the other Kona settings, but guess he hasn’t had time.
Page 2 of 2
