Activity Forums AJA Video Systems Kona LHI and Broadcast Monitor
  • Kona LHI and Broadcast Monitor
    Posted by Eddie Stein on June 2, 2010 at 1:20 pm
    Thank you Creative Cow members in advance for reading/responding to my post.
    Currently I have a MacPro 2.26ghz, Aja Kona LHI breakout box and a TV Logic LVM-172W Broadcast monitor setup. The broadcast monitor is hooked up to the AJA breakout box via HDMI converted to DVI. My problem is that I am unable to calibrate the broadcast monitor correctly. I am calibrating using brightness, contrast, bluegun, color and hue and I believe I understand to proper way to use those controls.
    I tried using smpte bars from Final Cut Pro, and I tried exporting bars from Avid Express Pro and imported them into FCP for output to the broadcast monitor. For some reason, no matter how much I adjust the contrast or brightness, I can’t get the three smpte pluge bars to separate. They all stay the same black color. So the picture looks somewhat muddy. This is a brand new monitor. Is there something else I can do to properly calibrate this monitor?
    Thank you so much for your thoughts.
    Eddie
    Thank you very much.
    Eddie Stein replied 16 years, 3 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    June 2, 2010 at 6:15 pm
    [Eddie Stein] “he broadcast monitor is hooked up to the AJA breakout box via HDMI converted to DVI. “
    Why not HDSDI?
  • Eddie Stein
    June 2, 2010 at 8:15 pm
    The wrong cable was ordered but I Thought HDMI was OK. Is it not OK?
  • Jeremy Garchow
    June 2, 2010 at 8:17 pm
    HDMI is ok, but perhaps the DVI connection on the monitor isn’t. Try hooking it up HDSDI and see if it works.
  • Eddie Stein
    June 2, 2010 at 8:21 pm
    I will. Thanks.
  • Eddie Stein
    June 11, 2010 at 12:02 pm
    switching to HD SDI did the trick. Thanks.
