Activity › Forums › AJA Video Systems › Kona LHi and 12 channels of audio
  • Kona LHi and 12 channels of audio
    Posted by Shane Ross on May 29, 2010 at 12:12 am
    OK…here’s the rub. My current setup is a MacPro with a Kona LHi card. But our deliverable requires a 12 channel output… well, it requires audio on 1-4, and then 11-12. THe LHi is limited to 8 channels of embedded via SDI. So the question is, how can I output channels 11-12? I certainly have to do two passes…but how can I map audio to 11-12?
    Shane
    Shane
    Mark Spano replied 16 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 29, 2010 at 12:53 am
    Nevermind. Gonna output to 7-8 and dub to 11-12 when we dub to add in closed captions.
    I miss my Kona 3.
    Shane
  • Mark Spano
    June 1, 2010 at 3:43 pm
    I assume this is an SR output? If so, you could do a separate sequence for just the audio for 11 and 12 and use the LHi’s AES output connected to the 11/12 AES input on the deck. Yeah, you can’t get them all there at once (AFAIK with LHi), but you can still make it happen.
