Activity › Forums › AJA Video Systems › Kona LHI and 1080p25
  • Kona LHI and 1080p25
    Posted by Julien Basset on June 4, 2010 at 8:25 am
    Hello
    First of all, sorry for my poor english.
    MACPro 2*2,66 Dual Core
    FCP 6.06 – Mac OS 10.6.3
    Kona 7.5.1 NDD
    Footage : EX3 XDCam 1080 p25
    Monitoring : JVC TMH1750C (Analog SD)
    1/My problem : In FCP esay setup i dont find the 1080p25(prores and others)
    Kona told me to reinstall the software and put additional Custom Setup driver install.
    I didi it and nothing change : I have the 1080i 25 and 29,97the 1080 p 23,98, 50 and 59,94 and the 1080psf.
    But no 1080 P 25.
    https://img340.imageshack.us/img340/435/easysetup.jpg
    Is it normal ?
    2/ When i am in FCP and push apple H i go back to the finder.
    My monitor show me like a remanant image like this :
    https://img189.imageshack.us/img189/5696/photo006dc.jpg.
    Thanks a lot
    Jeremy Garchow replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    June 4, 2010 at 2:59 pm
    It’s possible, but you will have to make your own easy setup.
    Are you sure you son’t need psf? If so, just use the 25i preset then modify your captured clips in the browser to a field dominance of none. That will create a progressive workflow.
    If you truly need 1080p, then setup your control panel like this:
    Then setup the video out of FCP like this:
    Then create a 1080 timeline in the codec of your choice and set the frame rate to 25 and a field dom of none.
    Jeremy
  • Julien Basset
    June 7, 2010 at 12:51 pm
    Hello and thank you a lot for your advice.
    I tried several time what you recomment but my picture on my monitor is
    bad quality.(compare when i m in 1080i25 in FCP)
    I discover something very surprising :
    When i put 1080i25 in FCP my kona is like this :
    https://img191.imageshack.us/img191/6296/konafcp.png
    I have the ” down convert symbol ”
    But when i choose 1080p25 in FCP Kona is like this :
    https://img43.imageshack.us/img43/5756/konaa.png
    So the down convert symbol is gone ….
    So maybe its why my picture quality is bad ….
  • Gary Adcock
    June 7, 2010 at 1:58 pm
    [julien Basset] “But no 1080 P 25. “
    The default format for 1080 is PsF (interlace) which AJA calls 25i because of EU labeling laws
    If you are talking about TRUE P playback you need to re-install and select the P setups- they are rarely used outside of RGB workflows and not installed by default.
    a quick google search can explain PsF vs P
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Jeremy Garchow
    June 7, 2010 at 3:46 pm
    I missed that you are monitoring SD. Sorry for omitting that detail.
    So you have HD footage and are monitoring SD via analog component, is that correct?
  • Julien Basset
    June 7, 2010 at 3:53 pm
    Thanks a lot.
    “If you are talking about TRUE P playback “
    No, my video monitor it s JVC SD so he can only eat Interlace video
    I just want to have the best monitoring of my EX3 XDcam footage 1080p25 pass by the kona to my JVC SD only ! ( so 625i i suppose)
    At the end i want burn a DVD SD whith that.
    ps :Why the down convert symbol is present in 108i25 and not in 1080p25 ?
  • Julien Basset
    June 7, 2010 at 3:56 pm
    oh i didnt see your post when i wrote the laste one …..
    Yes i have only SD and i have just analog composite for the moment.
  • Jeremy Garchow
    June 7, 2010 at 4:11 pm
    [julien Basset] “ps :Why the down convert symbol is present in 108i25 and not in 1080p25 ? “
    Because the card can’t down convert from 1080p due to the truly progressive scan nature. The card must be in interlace mode (which is how psf is handled) to down convert 1080 material.
    Putting your card in 1080i and setting the analog output to secondary is how you must do it. Then set the Analog Out to composite + y/c in the Control Panel.
    Jeremy
