Activity Forums AJA Video Systems Kona LHe Sync drifting
  • Kona LHe Sync drifting
    Posted by Kurtis Post on December 4, 2007 at 3:48 pm
    OK I’ve gone over all the threads and can’t fix this issue. I have a 40 min sequence and in playing thru the A/V sync gradually drifts. once stopped and restarted sync is back on at first then begins to drift again. I’ve done everything I can think of. Kona is in a 4x Lane, Trashed preferences, reinstalled drivers, reinstalled QT, The guy at AJA told me to zap the p-ram so I did that. Nothing is working. Any other suggestions. I have the exact same configuration on 3 other FCP systems and they are not having this issue.
    David Roth weiss replied 18 years, 9 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    December 4, 2007 at 4:46 pm
    [kurtis post] “Kona is in a 4x Lane,”
    Does that mean you have the Expansion slot Utility set to option #2?
    What kind of hard drive are you playing back from and what kind of media?
  • David Roth weiss
    December 4, 2007 at 5:00 pm
    Have you tried unistalling the Kona drivers (using the Kona uninstall utility) and reinstalling? I once had a similar issue that this cured.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Kurtis Post
    December 5, 2007 at 5:19 pm
    AJA requires setting the slot speed to 4x for proper performance. you can find this utility on the system/library/core services/drive slot utility
    Option 2 is the proper config
    I’m playing back from a dual 320 SCSI Rorke Data raid and it’s standard def DV/DVCPRO at 25% quality
  • Kurtis Post
    December 5, 2007 at 5:20 pm
    I’ve reinstalled but not uninstalled, will give this a try
  • David Roth weiss
    December 5, 2007 at 5:28 pm
    [kurtis post] “I’ve reinstalled but not uninstalled, will give this a try”
    Think of it like changing the oil in your car. You wouldn’t think of adding the new oil on top of the old oil, right?
    David Roth Weiss
    Director/Editor
    Los Angeles
