Activity Forums AJA Video Systems Kona LHe Stereoscopic capture
  • Kona LHe Stereoscopic capture
    Posted by Tom Bell on July 23, 2012 at 4:51 pm
    Can someone tell me if I can capture a “dual stream” 3D sdi signal, output from an SRW 5800 on my LHe capture card?
    Tom.
    Gunter Hemeleers replied 14 years, 1 month ago 3 Members · 2 Replies
  • Mark Spano
    July 23, 2012 at 5:44 pm
    I don’t think you can capture multiple streams at once with LHe. It has one SDI input. However, you should be able to capture them separately. The deck should have a feature in its VTR Setup menu to choose which stream will play out the standard 1.5G HD-SDI port. Set to Stream A, capture, switch to stream B, capture again. You’ll have separate L and R files, which most 3D post pros know how to work with.
  • Gunter Hemeleers
    July 24, 2012 at 12:40 pm
    The Kona3G will be able to do it.
    Hemeleers Gunter
    Mac Pro, Imac 24″, Macbook Pro 15″ all intel
