Activity Forums AJA Video Systems kona LHe playback delay on SDI
  • kona LHe playback delay on SDI
    Posted by Mauro Ruvolo on October 15, 2009 at 7:28 pm
    Hi everybody and thanks in advance for your help
    I’ve recently upgraded to FCS3 and since then I had a problem with my Kona LHe
    The monitor connected to Kona through SDI is 2fr delayed
    Of course setting the Frame Offset to 2 I solve the problem but why the value isn’t 0 how it should be?
    I’ve uninstalled and installed again Kona 7.0, the slot placement should be ok, and it was before the upgrade (kona on slot3 with the 2nd PCI profile and a dual Fiber card on slot4)
    Any idea?
    MacPro Intel 2×2.66Ghz
    Internal RAID0 1TB
    Xserve RAID 2TB (temporarely disconnected for repair)
    8GB RAM
    AJA Kona LHe with external box
    Panasonic DT-V24L1D full HD monitor
    Mauro Ruvolo replied 16 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    October 15, 2009 at 10:13 pm
    [mauro ruvolo] “Panasonic DT-V24L1D full HD monitor “
    This is probably the cluprit. Your LCD monitor is taking a few frames to process the video/audio.
    Jeremy
  • Mauro Ruvolo
    October 16, 2009 at 8:14 pm
    thanks for reply jeremy
    I’ve just tried to trash pref and it’s better, but I have the sensation there’s still a frame off (maybe before was more than 2fr, kind of 3 or 4)
    I don’t think it’s something related to the LCD cause everything was fine before the upgrade
    I can just set the frame offset to 1, but I wonder what’s behind this issue, makes me feel kind of unstable
    I also tried to connect a samsung plasma 50″ just to have a bigger view sometimes, but out-of-sync issues persecute me! But this time I think it’s because consumer plasma TVs need some time to upconvert an SD signal, so there’s not much to do. I’ll use it for dvd visions
