Activity › Forums › Blackmagic Design › KONA LHe PCIe or DeckLink Extreme PCIe for Quad/FCP5. Conversion for PAL 25/50 needed?
  • KONA LHe PCIe or DeckLink Extreme PCIe for Quad/FCP5. Conversion for PAL 25/50 needed?
    Posted by Thomas Saron on December 28, 2005 at 7:01 am
    Which of these cards is better for HDV? – I will connect a Dell 2405. (or cineama display 23′?)
    I heard that both cards are problematic when you have to work in PAL 25/50 because you have to work in 30/60 and convert – which does not look good … – Any experiences from PAL-users?
    What is a proper PAL-solution for PCIe?
    Does the Decklink do HDV at all or just SD?
    BTW: Anyone with experiences with Quad and HDV? How fast is native HDV-editing
    Thomas Saron replied 20 years, 9 months ago 2 Members · 9 Replies
  • 9 Replies
  • Jonathan Smiles
    January 2, 2006 at 9:50 am
    Both cards work natively 25/50.
    The 60Hz limitation is the Dell monitor which is native 60Hz like the Apple Cinema Displays.
    [nookynook] “What is a proper PAL-solution for PCIe?”
    We have both AJA LHe and Blackmagic Multibride Extreme in client systems here, they both work well.
    [nookynook] “Does the Decklink do HDV at all or just SD?”
    The PCIe Extreme will do HDV in downconvert mode.
    Native HD PCIe Blackmagic cards are coming soon and Multiibridge Extreme is shipping now for not much more than the LHe with KL Box.
    [nookynook] “BTW: Anyone with experiences with Quad and HDV? How fast is native HDV-editing”
    I have Quad Core G5s here with 6600, 7800 and Quadro graphics cards here, HDV is speedier but still not like running DV. You will get better results by bumping to uncompressed HD for finishing or DVCPRO-HD if you don’t have the storage.
    Jonathan Smiles
    Managing Director/CEO
    Digital Safari Ltd
    UK – Specialist Reseller
    dCinema – HD – SD
    https://www.digitalsafari.co.uk
  • Thomas Saron
    January 2, 2006 at 10:21 am
    hi jonathan,
    thanks for your answer. just been to your website. looks as if you know what you are talking about … convincing concept! it’s a pitty you are not located in germany.
    — my german reseller told me something different. but you will know better.
    — so you don’t think it is a good idea to use them for hdv-monitoring when working in pal? which monitor do you recommend? pricy sony ones?
    — what is the cheapest solution?
    — dvcpro hd still takes a lot disk space … i am doing longform-features with hundreds of hours of video … was hoping the quad would manage hdv like a “usual g4/g5” manages dv …
  • Jonathan Smiles
    January 2, 2006 at 10:38 am
    [nookynook] “it’s a pitty you are not located in germany.”
    I have HD clients all over the World from Iceland to South Africa, USA to Slovenia, so provide consultancy worldwide but would recommend you buy your hardware locally.
    [nookynook] “— so you don’t think it is a good idea to use them for hdv-monitoring when working in pal? which monitor do you recommend? pricy sony ones?”
    My preferred low cost option is the 19inch 4:3 (17inch 16:9) JVC HD CRT fed using analogue HD component.
    [nookynook] “— what is the cheapest solution?”
    Blackmagic is always the lowest cost solution!
    [nookynook] “— dvcpro hd still takes a lot disk space … i am doing longform-features with hundreds of hours of video … was hoping the quad would manage hdv like a “usual g4/g5″ manages dv …”
    Is all the material shot on HDV ?
    Are the features being sold as HD ?
    Jonathan Smiles
    Digital Safari Ltd
    dCinema – HD – SD
  • Thomas Saron
    January 2, 2006 at 10:51 am
    (…)but would recommend you buy your hardware locally.
    —yes, me too.
    —yes, i heard about this one! but when it comes to lcd – does it make sense to use the 60hz dell or apple-displays at all in a pal-enviroment?
    — then i’ll wait for the native hd-card.
    — not yet, but that’s what i am aiming at.
    — no. i am just hoping to get better sd-results by editing native hdv and bringing the hdv-master-tape to a post-production-house in order to let them make a digi-beta-copy. what would you suggest? edit the downconverted material (downconverted by the z1 or by fcp5)? – and maybe “online” the final timeline in hdv?
  • Jonathan Smiles
    January 2, 2006 at 11:21 am
    The HP 23inch syncs at 50Hz.
    [nookynook] “what would you suggest?”
    If your shooting with a Z1 for SD release, you might as well capture HDV, then bump to uncompressed SD and use Graemes Nattress’ 4:2:2 sharpening filter.
    I don’t recommended doing any finishing in HDV mode.
    Jonathan Smiles
    Digital Safari Ltd
    dCinema – HD – SD
  • Thomas Saron
    January 2, 2006 at 11:35 am
    thanks for the hint. i’ll try the hp L2335. just checked it. has got component in as well.
    gaemes nattress filters are great. already using them.
    up to now i don’t know exactly how and when to “bump hdv to uncompressed sd” (the finished sequence?) – but i’ll try. also heard that hdv is not so good for doing cc, effects etc.
  • Thomas Saron
    January 2, 2006 at 12:00 pm
    Are you sure about the HP?
    that what i found at their website:
    Resolutions supported All VESA standard video modes up to 1920 x 1200 @60Hz also supports some Sun and Mac models
  • Jonathan Smiles
    January 2, 2006 at 1:40 pm
    Abtastraten
    Horizontalfrequenz: 30-94 kHz (VGA), 30-92 kHz (DVI), Vertikalfrequenz: 48-85 Hz (VGA & DVI)
    It does 50Hz.
    Jonathan Smiles
    Digital Safari Ltd
    dCinema – HD – SD
  • Thomas Saron
    January 2, 2006 at 1:46 pm
    thanks a lot!
    then i misinterpreted this:
    1920 x 1200 @60Hz
