Activity › Forums › AJA Video Systems › Kona LHe output garbage frame when there’s empty gap on timeline
  • Kona LHe output garbage frame when there’s empty gap on timeline
    Posted by Ben Cheng on December 22, 2005 at 3:47 pm
    Anybody experience this ?
    – Problem :
    When there’s empty gap on timeline, the Kona LHe video output displays a flickering garbage frame
    Once there’s video media, the playback is fine
    If stop & play from empty gap, it will output the last frame of video when stopped, flickering
    Affects only “PAL 8bit to DV” media captured through LHe
    8bit Uncompressed media is fine
    Sequence presets match the media codec
    Tried using different “video playback device” & no affect
    Tried “refresh audio/video devices” & no affect
    – Workaround :
    Insert a slug in the empty gap
    – System Config :
    Apple PM G5 Quad 2.5Ghz
    ATTO UL5D – Slot 3
    AJA Kona LHe – Slot 4
    4GB RAM
    Huge U320R-1200GB – RAID/2k
    OS X 10.4.3
    QT 7.0.3
    ATTO 3.5.0
    FCP 5.0.3
    AJA 1.1.6
    Cheers,
    Ben Cheng
    The Media Village
    Singapore
    Michael Costa replied 20 years, 8 months ago 3 Members · 4 Replies
  • Walter Biscardi
    December 27, 2005 at 1:14 pm
    You should always have a slug in an empty gap. I see that here occassionaly in DVCPro HD timelines where I’ll get garbage in gaps until a Slug gets dropped in.
    You can probably also insert an empty Title in the gap to get rid of the garbage.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Michael Costa
    December 29, 2005 at 12:08 am
    Absolutely confirmed here. I was about to post the same problem. Of course, it doesn’t affect your final output – it’s a dsiplay issue only but it should be fixed.
  • Ben Cheng
    January 3, 2006 at 3:39 am
    Hi
    Thanks for your advice & replies
    May I know if you experience the garbage issue when a filter is applied on the clip ? e.g color correction ?
    Once the color correction filter is applied, the output becomes garbage, hence unable to use that
    Wonder if anyone else has the same issue & found a solution ?
    Cheers
    Ben Cheng
    The Media Village
  • Michael Costa
    January 8, 2006 at 10:38 am
    As I mentioned: For me it was only a monitoring thing, albeit a damn annoying one! This was because I transcoded the timeline to MPEG2. Had I been outputing the timeline to DigiBeta, I don’t know if the problem would have gone with it. I haven’t tested that yet. If it does, then we got a bad problem here – Aja?
