Activity Forums AJA Video Systems Kona LHe Offline workflow in 720X486?
  • Kona LHe Offline workflow in 720X486?
    Posted by Tyler Granlund on March 7, 2006 at 11:32 pm
    I have been using DV as my offline codec for a while now, and am running into issues with my graphics, (photoshop layers maily) failing to line up properly in my Online version, after capturing uncompressed 720X486, being that DV is 720X480, there is no way to accurately work withjin the frame for graphic intense shows, especially ones with many animated layers. Can anyone recomend an offline solution that will keep my offline footage in the 720×486 frame size it is being finished in? If only the quality slider worked…..
    Jeremy Garchow replied 20 years, 6 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    March 8, 2006 at 12:27 am
    What I do is create my graphics in 720×486 and then use those in the 720×480 offline. When you put the bigger graphic in the timeline. FCP should automatically put a -1 in the vertical position value in the motion tab. The pain is when you of the online you will have to manually go through and adjust each one up back to a 0,0 position. You can do this easily by selecting all of the graphic clips in the timeline and control clicking one clip and selecting remove attributes and then select basic motion, but BE WARNED if you have moved or keyframed anything this will blow those moves/keyframes away. Then you are stuck doing those clips one by one. This should only effect anything with video in it. Stills shouldn’t make a difference as they are not interlaced. When you put a 720×486 video graphic in a 720×480 timeline, you are essentially reversing the field order until you shove it down a pixel, that’s why it won’t look correct. If you can’t recreate your graphics for the online, then simply do the same thing. Shove your 720×480 video graphic down a pixel and all should be well in 720×486 land. You will of course need to render everything. I have always wished and wanted capture card companies would devise their own offline/online codecs so that we could work easier without going through this rigamarole, but I digress. I am just keeping hope alive and thinking that this will be addressed in some future version of FCP.
    Make sense?
    Jeremy
  • Tyler Granlund
    March 8, 2006 at 12:41 am
    Thanks Jeremy, it makes sense, and is somehting I have been doing here and there, but like you was hoping to not have to deal with that damn -1 shift, it’s driving my online guys crazy. Maybe AJA or Apple will release something that works….probably not though.
  • Jeremy Garchow
    March 8, 2006 at 3:01 am
    AJA just recently made MJPEG-A available, now that I am thinking about it. You should try that codec out and see if it works for your offline. You will have to create a new easy setup, but it might work. Check out the AJA site for the FAQ on MJEPG-A. I’m going to try this out myself.
    Jeremy
  • Jeremy Garchow
    March 8, 2006 at 3:04 am
    Here’s the pdf:
    https://www.aja.com/pdfs/MJPEG_FAQ.pdf
    Jeremy
  • Jeremy Garchow
    March 8, 2006 at 3:09 am
    Woops, looks like it’s a playback only codec. Damn, I thought I might be on to something.
