Activity › Forums › AJA Video Systems › Kona LHe – Is the data rate always different?
  • Kona LHe – Is the data rate always different?
    Posted by Ben Cheng on December 2, 2006 at 5:48 pm
    Hi All,
    I like to find out more about this observation about the data rate of Uncompressed 10bit media, captured using a Kona LHe.
    Is it normal for the data rate to go up & down, ranging from 23MB/s to 27MB/s?
    This faculty has 2 FCP systems, 1 running Decklink Extreme & the other Kona LHe.
    On the Decklink system, the data rate is constant, for all media.
    On the Kona LHe system, the number goes up & down.
    Cheers,
    Ben Cheng
    The Media Village
    Ben Cheng replied 19 years, 9 months ago 3 Members · 5 Replies
  • Bob Zelin
    December 2, 2006 at 6:15 pm
    What is the real reason for your question? Are you trying to determine what
    drives to use with your system to 10 bit uncompressed video ?
    Bob Zelin
  • Jeremy Garchow
    December 2, 2006 at 8:42 pm
    What are the frame rates for each type of capture?
  • Ben Cheng
    December 5, 2006 at 7:54 am
    Hi Bob & Jeremy,
    This particular system is quite unstable for a while, dropping frames regularly. Even when the Huge U320R-600 is less than 10% full.
    I have been troubleshooting this system and we replaced the G5 motherboard and CPU before.
    Some of the actions taken:
    – Replaced faulty CPU = No more loud blowing fans
    – Swapped a new brand internal SATA disk, with a fresh install of Mac OS X
    – Re-installed Mac OS X 2 weeks ago
    – Huge U320R-600 passed Internal Disk Speed Test
    The customer noticed the data rate is not fixed and the no. will range from 23MB/s to 27MB/s.
    On the other system with Blackmagic, this does not happen.
    I remembered on other systems with Kona cards, the data rate does not change too.
    Both Kona and Blackmagic systems are working on PAL Uncompressed 10bit only.
    Cheers,
    Ben
  • Bob Zelin
    December 5, 2006 at 11:05 pm
    Ben –
    your dropped frames are due to a drive issue. Run AJA Kona System Test on the HUGE array, and report back your results, in read and write speeds in mb/sec. This will help determine what is going on. I am not there, and for all I know, you client is trying to record on the internal hard drive of the MAC.
    Bob Zelin
  • Ben Cheng
    December 15, 2006 at 8:48 am
    Hi Bob,
    I downgraded the Kona driver from 3.3 to 3.0, as the FCP is 5.0.4.
    So far the data rate is more constant, around 26.7MB/s.
    A weird issue that has been bugging this system is the mouse cursor disappear, during editing or no user or system activity after a while, e.g 30min.
    We swapped the boot disks, different versions of Mac OS X and replaced the motherboard and CPU before.
    Next I’m going to swap the ram and replace with new ones.
    Cheers
    Ben Cheng
