Activity Forums AJA Video Systems Kona LHe + G5 + HDCAM Deck = ProRes footage?
  • Kona LHe + G5 + HDCAM Deck = ProRes footage?
    Posted by Greg Leuenberger on January 8, 2009 at 4:32 pm
    Hi, I typically work with footage from a P2 camera but a client of mine wants to bring in an HDCAM deck to capture some 1080 59.94 footage. The system I want to use is a Quad G5 2.5 GHz with a Kona LHe and a 4 Drive Raid capable of 200 MB/Sec. AJA’s site seems to indicate that a Quad G5 is capable of capturing proRES at HD res….not sure if it’s proResHQ though…I’m curious if anybody has actually done this though before I commit to it.
    If worst comes to worst I can put the LHe in an 8 core 3.0 GHz Mac Pro…I would just rather not hassel with it. Also, can I just set the HDCAM deck to internal sync? I would be willing to buy a Gen10 but it seems like I should get away without having to provide sync if I’m just capturing from a deck directly hooked up to the Kona (at least my Pana DV50 deck is fine with no sync).
    thanks in advance,
    Greg
    Greg Leuenberger
    CEO
    Sabertooth Productions, Inc.
    http://www.sabpro.com
    Greg Leuenberger replied 17 years, 8 months ago 3 Members · 5 Replies
  • Gary Adcock
    January 8, 2009 at 11:51 pm
    [Greg Leuenberger] ” AJA’s site seems to indicate that a Quad G5 is capable of capturing proRES at HD res….not sure if it’s proResHQ though”
    nope….
    You will not be able to capture HD as ProRes on a G5 computer.
    the G5 machines do not have enough power to capture HD footage as ProRes HQ.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Greg Leuenberger
    January 9, 2009 at 12:23 am
    Thanks Gary, I guess I’ll be hooking up the 8 Core then…
    -Greg
    Greg Leuenberger
    CEO
  • Gary Adcock
    January 9, 2009 at 2:43 pm
    [Greg Leuenberger] “Thanks Gary, I guess I’ll be hooking up the 8 Core then… “
    Sorry
    but thats the way it is…
    gary adcock
    Studio37
  • Larry Asbell
    January 9, 2009 at 8:34 pm
    The fact that your source is 1080 at 30 frame/sec puts it just over the line for what a Quad G5 can capture in ProRes. A Quad G5 will capture ProRes at 1080 at 24 fps.
    An alternative, if the amount you have to capture is not too much, would be to capture in Uncompressed 10-bit and transcode the files to ProRes. Your machine can handle that because the computation for compressing to ProRes can proceed in less than real time.
  • Greg Leuenberger
    January 9, 2009 at 9:40 pm
    Yeah, I would normally go that route except my RAID is going to be a hair under what’s capable for uncompressed 1080…so I think I’ll just switch the Kona over to the 8-Core (or stripe across 2 raids…that would probably give me enough bandwidth for 1080 uncompressed)
    -Greg
    Greg Leuenberger
    CEO
