Activity Forums AJA Video Systems Kona LHe dropping frames on a 3 ghz Mac Pro
  • Kona LHe dropping frames on a 3 ghz Mac Pro
    Posted by Art Guglielmo on October 14, 2006 at 12:30 pm
    I am using a Kona LHe on a Brand new Mac Pro (Dual 3 ghz, 5 gig ram)
    If I leave the “report dropped frames” option “on” while editing a DVCPro HD 1080i project on my Mac Pro I get it stopping almost every playback, saying a frame has been dropped. No effects or anything, just playing back, it stops and says “frame dropped”. If I turn off the option, the video seems to play ok, so I dont know what is going on. It does this playing back from both a firewire drive, and an internal 1 TB SATA Raid drive.
    If I take that Exact firewire drive, plug it into my old Dual 2.0 G5, with all the settings the same, it plays back without stopping. That machine has a Decklink HD Extreme card.
    I definitely believe it has something to do with the Kona card, because if I turn off the external monitor, or switch it to Desktop Cinema Preview, it plays back fine. Same exact project. And, as I said, the same project plays back fine from an older G5, on a firewire drive, no less.
    I know what the first suggestions will be, so I have already reinstalled the OS, and running the current version of FCP (5.1.2), and have all my Kona drivers up to date.
    Please, someone give me some ideas. I didnt spend $6000 on a new system to get less performance than I had 2 years ago.
    Walter Biscardi replied 19 years, 11 months ago 6 Members · 20 Replies
  • 20 Replies
  • Bob Zelin
    October 14, 2006 at 5:37 pm
    you are not being clear here about your firewire drive. From the old 2 Gig computers, to the current MAC Pros, and everything in between, you need AT LEAST a FW800 card to do DVCProHD. If you are using a FW400 drive, I have no idea of how you got it to work reliably all these years, but you should have been playing the lottery. You can’t do DVCProHD on a FW400 drive. As for SATA drives, which is all I have been using in countless systems for the past 1 1/2 years, you need at least TWO SATA drives stripped RAID 0 to get reliable playback of DVCProHD. If you are in a MAC Pro, stick TWO SATA drives into the MAC Pro, stripe them together with Apple Disk Utility RAID 0, and you will have no problems. You can use AJA Kona System test to test the speed of the drives. Two SATA drives will give you about 120mb/sec, which is more than enough to do anything with DVCProHD.
    Like I said, you were not clear about your FW drive – FW400 or 800. If your 800 is giving you drop frame errors, there may be issues with your drive, but if you can’t get your FW400 drive to do DVCPro HD, well, no one can. And if you have been doing it for the past two years, well, you are lucky.
    Also, I assume that you have gone to EASY SETUPS in FCP, and selected the AJA Kona DVCProHD codec.
    Bob Zelin
  • Art Guglielmo
    October 14, 2006 at 10:08 pm
    Sorry. Actually its a Lacie 500 gig firewire 800. Works great. The internal is (2) 200 gig SATA striped as raid 0, with the Kona card test giving me about 115 – 120 mb/sec. The Lacie is getting about 45 write, 73 mb/s read. Same exact symptoms from either drive.
  • Jeremy Garchow
    October 14, 2006 at 10:44 pm
    You have something set up funky somewhere.
    Jeremy
  • Bob Zelin
    October 14, 2006 at 10:57 pm
    I agree – if you are getting these good numbers on your SATA drives, and still getting dropped frames, something (and I don’t know what) is setup incorrectly. I know that you want suggestions, and I usually have them (weather I know what I am talking about, or not), but not this time. I can’t imagine why you are getting dropped frame errors with drive speeds like this.
    Bob Zelin
  • Aja Sales department
    October 14, 2006 at 11:13 pm
    Hello,
    If you are still having issues, you are welcome to contact our technical support department who can help diagnose what may be going on. They can be reached via email at support@aja.com, or via phone during PST business hours, +1 (530) 271-3190.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Art Guglielmo
    October 15, 2006 at 7:42 pm
    I will call AJA again on Monday. I guess I should let you know I did call AJA on Wednesday, and was told to “turn off the report drop frames” option, as this is normal, and has something to do with the “handshake” between the card. Maybe I just got the wrong guy that day, and will give AJA another shot, as to be honest, I do not believe that this is normal, and if it is, someone let me know, so I can return this card, and shop for something else, as that should be unacceptable. (unless someone can really convince me that this should be happening, but I sure dont see anyone else on this forum saying they have this problem.)
    Also, when I turn off the output through the Kona card, either with no output or desktop cinema display, the timeline plays fine. So it has to be something with the Kona card, and not the disk sub system.
  • Jeremy Garchow
    October 15, 2006 at 10:05 pm
    Yeah, that’s weird, but the MacPro is new so there’s going to be some growing pains in how everything works together.
    How well do you know FCP and how to set up and install an FCP system? I am assuming that you know what you are doing, I am just asking for clarification so I can try and help you. Please don’t take my questions as rude or unfounded. I am trying to help. There are a zillion reasons for dropped frames and I have to say most of them involve operator error. The most common reason (besides slow drives which you have ruled out) have to do with your sequence and media format not matching and having your media play from different drives (for instance if you have music playing from your boot drive instead of your media drive). Also, the kona card’s frame buffer should match the format you are trying to do output, choosing the correct easy setup will fix this. Also, mixing down your audio takes care of a lot of these things.
    Let’s start there, and turn your dropped frames preferences back on. That’s bad advice (sorry AJA).
    Jeremy
  • Bob Zelin
    October 15, 2006 at 10:30 pm
    this particular post has taught me a valuable lesson. WAIT on buying a Mac Pro – let someone else suffer this out (between the 2 Gig issues, the firmware issues, the SATA and ATTO issues – I can wait another 60 days).
    Bob Zelin
  • Art Guglielmo
    October 16, 2006 at 11:30 am
    I have been editing on Final cut since version 2.0. Between the computer, Kona, drives , memory, etc, I am in for over 10 grand total. (and I have a 2 year old G5 with a Decklink card that works better. Not good)
    I am very experienced in Final Cut, but what I am not experienced in is KONA. This is my first Kona card, and I am trying to figure out if there is some magic setting I am missing.
    I am a serious user, and have been for years. I wanted to keep them out of it, but this system was set-up by ProMax, and they were even able to log-in remotely and try to work on the problem, and even they have no ideas. I normally NEVER call tech support, as usually I feel I am quite sophisticated when diagnosing problems such as this. No offense to AJA, but when you get answers like they gave me, you tend to lose confidence in tech support. The fact of the matter is, this shouldnt be a tough problem to work out. The machine is brand new, with barely any media or other programs installed. Generally I am working with footage imported from an HVX, and its simply a matter of selecting the right “easy Setup”. The problem happens on every type of media though, including new media digitized through the Kona Break-out box.
    This is not a mismatch error, or problems with set-up. As I stated before, just turning off the Kona output clears the problem up. I was really just hoping someone here had a magic answer, so now after seeing the replies, I am more confident there is a serious problem, either with the card or the Mac Pro. I will give AJA another shot, then I will be exchanging the card for another card, possibly another decklink. I was really excited about the Kona, and some of its advantages, but unfortunately, this isnt working out.
    Does anyone else out there have a Kona with a Mac Pro that can verify this isnt a common issue ?
  • Gary Adcock
    October 16, 2006 at 1:10 pm
    [artgug1] “Also, when I turn off the output through the Kona card, either with no output or desktop cinema display, the timeline plays fine. So it has to be something with the Kona card, and not the disk sub system.”
    Not True.
    the Kona card is receiving the drop frame warning from FCP, by turning off your Kona Card you are turning off the warning. YOu never have mentioned whether the old systems you are testing has the exact same hardware / software set up? Older versions of the software do not always give this report.
    What is the FW drive attached to?
    are there other things on the buss?
    How full are the drives( and a single drive in a case is not really fast enough to consistently play 10860i)
    are both machines on 5.1.2 / QT 7.1.3
    The MP Machine Is NOT on 10.4.8.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
