Activity › Forums › AJA Video Systems › Kona LHe downconvert vs. FCP Sequence “downconvert” Questions
  • Kona LHe downconvert vs. FCP Sequence “downconvert” Questions
    Posted by Bruce Alfred on December 4, 2006 at 6:14 pm
    I’ve got an HDV 1440 X 1080i project in FCP that I’ll also need at 525 720×486.
    Has anyone tested the quality difference between downconverting and printing to tape via Kona, vs. nesting the HDV sequence in a 720 X 486 sequence and printing that to tape? (My initial results show that the Kona downconvert produces better results — but I’m interested in other opinions.)
    Also, should the sequence that will be downconverted be kept at Upper Field, or set to Lower Field for D1?
    Finally, any tips on getting the playback offset right (other than lip syncing trial and error) would be appreciated. The Kona output preview has audio behind video on both my computer monitor and my ntsc monitor.
    Bruce
    Walter Biscardi replied 19 years, 9 months ago 2 Members · 1 Reply
  • Walter Biscardi
    December 4, 2006 at 6:19 pm
    Hardware downconvert is better than software.
    You may need to adjust your Playback Offset for the lip sync issue.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
