Activity › Forums › AJA Video Systems › Kona LHe composite out
  • Kona LHe composite out
    Posted by Jay Curlee on April 8, 2006 at 8:36 pm
    A dumb question I can’t seem to find an answer for in the documentation.
    How do I get composite out to a monitor. Or am I limited to component?
    Jay
    Jay Curlee replied 20 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Kevin Wild
    April 8, 2006 at 11:32 pm
    If it’s the same as the inputs, the left most connector for the component connections is a composite out. Man, I wish they had a separate composite out and in…it’d be a perfect box! Still pretty close, as it is now.
    Kevin
  • Erik Lindahl
    April 9, 2006 at 12:37 am
    Yes you get composite out. However, you have to set the analog out to “composite” as to “component” (or component RGB for that matter) in the AJA Controll-panel. That’s it, works very good for output to a TV-set. Sadly you do loose component out when doing this.
  • Jay Curlee
    April 9, 2006 at 1:01 am
    Do you know which color is the composite out. I don’t have a breakout box.
    Jay
  • Erik Lindahl
    April 9, 2006 at 1:08 am
    Oh, good question
  • Jay Curlee
    April 9, 2006 at 1:49 am
    I’ll just experiment. I have the adapter.
  • Roland Rudio
    April 9, 2006 at 11:42 am
    Kevin,
    Composite out is the Green out connector. If you want Y/C – use an S to BNC connector and take the output from Green and Blue outs – make sure you change your Analog out to Composite + Y/C in your Aja Control Panel.
    Roland
  • Jay Curlee
    April 11, 2006 at 7:12 am
    Thanks for the help. Works like a charm.
