Activity Forums AJA Video Systems Kona LHe capture closed captioning need help
  • Kona LHe capture closed captioning need help
    Posted by Colin Bonzey on November 15, 2007 at 5:32 pm
    My set up: MacPro with Final Cut Pro 6.0.1, Kona LHe, Sony Beta (UVW-1800) via component
    My issue: I’m attempting to capture a tape with closed captioning, edit, and export via the Beta deck and to keep closed captioning in tact. No matter which capture preset I use, it seems to be lacking the CC.
    Let me know if you have any suggestions..Is this a FCP issue? a Kona issue? or am I missing something glaringly obvious.
    Colin Mcquillan replied 18 years, 6 months ago 3 Members · 2 Replies
  • Gordon Gurley
    November 15, 2007 at 9:21 pm
    I think we had to use an Uncompressed format to preserve the CC. Any of the DV flavors seemed to remove it. Hope that helps.
  • Colin Mcquillan
    November 16, 2007 at 7:32 am
    This would make sense as DV codec cuts at 486 lines,, and proper uncompressed is 525 with a few of the extra lines that are outside of viewable carrying the cc text info…
    could be wrong,,, dont do any CC,,, just trying to remember when we touched on the subject in Broadcast Tech class some many years ago…
    Colin McQuillan
    Vancouver BC
