Kona LHe and 50 frs varicam capturing
I try to capture 50 frs footage from a varicam with the kona LHe on a Apple Quad system on a 25 frs sequence.
After capturing the clip (start and end time code) the clip is half the length? Even when I am using capture now and doubles the time it throws out half the clip.The slomo itself is useful in the 25frs sequence but the length is a problem! Can any one help me.
