Activity › Forums › AJA Video Systems › Kona-LhE 4 channel sdi audio output oddity
  • Kona-LhE 4 channel sdi audio output oddity
    Posted by Chris Borjis on October 7, 2009 at 4:36 pm
    the edit to tape window shows only 2 audio channels possible
    all the rest are grayed out.
    I found that an assemble edit actually did output 4 channels (I was doing stereo mix and dolby-e)
    but an insert edit did not.
    driver bug?
    Mark Spano replied 16 years, 11 months ago 4 Members · 5 Replies
  • Gary Adcock
    October 7, 2009 at 4:45 pm
    [Chris Borjis] “I found that an assemble edit actually did output 4 channels (I was doing stereo mix and dolby-e) but an insert edit did not.
    driver bug? “
    Could it be that assemble edits allow for mismatched settings where edit-to-tape setting adhere to stricter functionality?
    It is my understanding that the kona drivers technically do not support any type of Dolby audio.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Chris Borjis
    October 7, 2009 at 7:21 pm
    Interesting Gary.
    But the LHe “should” be able to output 4 channels of audio over SDI right?
    I know it ingests 8 and not 16 like the Kona3.
  • Jeremy Garchow
    October 7, 2009 at 11:33 pm
    Are you in editing or master mode?
  • Chris Borjis
    October 8, 2009 at 7:34 pm
    good question!
    editing mode.
    is that why?
  • Mark Spano
    October 13, 2009 at 5:40 pm
    Assemble is basically “insert edit, all available channels, including TC and CTL”. Edit to tape is “insert edit, ONLY on selected channels”. In FCP what you have available is determined by the Device Control Preset (in A/V settings). Drop down menu there will give you 2, 4, 8, etc. channels audio. Change this, apply, and you should see them available in your ETT window…
