Activity › Forums › Apple Motion › KONA LH vs. Matrox Axio
Posted by Les Kaye on September 13, 2005 at 6:39 amI’m not even considering leaving FCP for PPro, but I am curious if someone can spell out the major differences, pros & cons between the two (apart from the application exlusivity of both)
Les Kaye replied 21 years ago 3 Members · 3 Replies -
Walter Biscardi
September 13, 2005 at 2:34 pm[Les Kaye] ”
I’m not even considering leaving FCP for PPro, but I am curious if someone can spell out the major differences, pros & cons between the two (apart from the application exlusivity of both)”Might want to post this in the FCP forum.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
Christopher Wright
September 13, 2005 at 6:51 pmYes, the AXIO set-up is A LOT more expensive, and is like the the old Targa 2000 card with the Abekas 3-D board attached for hardware acceleration of the same type of Abekas-like effects. Especially if you already have FCP and an Apple, the answer is a no-brainer. Like the old Targa cards, this “solution” has EOL written all over it. Yet another expensive proprietary hardware doorstop!
Les Kaye
September 14, 2005 at 1:44 am[walter biscardi] “Might want to post this in the FCP forum.”
Thanks Walter – file this under not paying attention…
