Activity Forums AJA Video Systems Kona LH users
  • Kona LH users
    Posted by Heinz Tobler on November 7, 2005 at 9:57 am
    Thanks for your reply
    the first thing i did, was changing the the wrong PAL settings.
    Pixel aspect and field order. (The confusion is also in the manual, where ntsc settings are
    explained as 625 and pal as 525).
    When i capture and edit the footage everything looks good on my JVC DT-1910CG Monitor.
    When i play out to the IMX Recorder through SDI the result on tape is jitterd.
    This happens in SD Jpeg and 8Bit uncompressed.
    My setting is: OS 10.4.2 QT 7.02 Aja Driver 1.1.5
    Cheers Heinz
    EyeMix GmbH
    zurich switzerland
    kona sd/LH, pal
    http://www.eyemix.ch
    Heinz Tobler replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
