Activity › Forums › AJA Video Systems › Kona LH to DVD using Composite Outs
  • Kona LH to DVD using Composite Outs
    Posted by Guzman on August 31, 2006 at 9:10 pm
    I am using a Kona LH with breakout box. I have an SD FCP sequence I want to crash to DVD recorder. How do I change the component outs to be composite and which out is the composite once this is selected.
    Bob Zelin replied 20 years, 1 month ago 3 Members · 3 Replies
  • Walter Biscardi
    August 31, 2006 at 10:29 pm
    Not sure you can do that without the breakout box. But if you can, you go into your Control Panel and change the output to Composite. You then connect the Y cable from your Component set to the DVD Recorder. The Y connection doubles as the Composite connection when that option is selected.
    Again, not sure if you can do that with just the cable snake.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Guzman
    August 31, 2006 at 10:33 pm
    Thanks – I do have the breakout box…
  • Bob Zelin
    August 31, 2006 at 11:46 pm
    go to the Kona control panel, select analog, and change the analog output from component to composite – the Y out will become the composite output. you should spend time screwing around with the Kona control panel. It is very useful.
    Bob Zelin
