Activity Forums AJA Video Systems Kona LH First Tests in PAL
  • Kona LH First Tests in PAL
    Posted by Heinz Tobler on September 23, 2005 at 10:04 am
    Capture and Edit in SD works. HDV component analog out 1080i50 downconverted to SD captured through
    Kona LH component in, Codec: Photo JPEG worked, Picture and Audio in perfect sync.
    HDV analog component out 1080i50, captured via Kona analog component in DVC PRO HD did not work.
    HDV analog component out in converter to HD SDI, captured in Kona to DVC PRO HD worked except for the audio.
    Audio was completely out of sync.
    Is this a Beta software release problem or did i something wrong?
    Greetings from PAL land
    Heinz
    EyeMix GmbH
    zurich switzerland
    kona sd pal
    http://www.eyemix.ch
    Heinz Tobler replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
