Kona LH downconverted letterbox centering
Hi
I am having a problem with one of our two Kona LH cards. When we set the control panel to downconvert and letterbox to NTSC output, the letterbox is not centered but positioned a bit lower than center. About 5-10 pixels below center.
This problem persists no matter what we’ve tried. Source does not matter, bars, FCPro, Mac desktop ect. It’s there with a direct component connection to our monitors. We are not using the SDI outputs so I can’t check that. It’s not affected by genlock or source. The position of the letterbox doesn’t change. Reinstalling drivers doesn’t change it either.
Our 2nd system does not have this problem. It’s dead center.
Anyone have any suggestions to try?
Dave B
