Activity Forums AJA Video Systems KONA Lh crashes Color
  • KONA Lh crashes Color
    Posted by Nicolas Ayerbe on May 13, 2011 at 2:51 am
    Every time I select the Kona as Video Output, Color crashes and quits.
    I’m not sure what’s wrong, but I have a feeling that it might be a crappy video card. However, it does work fine in FCP 7, so I’m not sure what’s the deal.
    I’m bringing in your average DV-NTSC footage in a typical DV-NTSC sequence from FCP to Color 1.5. No other crazy high-def footage or anything like it, just plain old DV. Outputing to a Field Monitor from the Kona.
    Here’s the problem report for those who know:
    Process: Color [555]
    Path: /Applications/Color.app/Contents/MacOS/Color
    Identifier: com.apple.color
    Version: 1.5.3 (596)
    Build Info: Color-5960000~56
    Code Type: X86 (Native)
    Parent Process: launchd [109]
    PlugIn Path: /Library/QuickTime/AJAMuxer.component/Contents/MacOS/AJAMuxer
    PlugIn Identifier: com.aja.kona.muxer
    PlugIn Version: 8.1.2 (8.1.2)
    Date/Time: 2011-05-12 19:50:39.336 -0700
    OS Version: Mac OS X 10.6.7 (10J869)
    Report Version: 6
    Interval Since Last Report: 183188 sec
    Crashes Since Last Report: 9
    Per-App Interval Since Last Report: 5358 sec
    Per-App Crashes Since Last Report: 8
    Anonymous UUID: 13B74652-3528-4627-A075-3BD9DB8E626B
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x000000004b6f6e58
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 com.aja.kona.muxer 0x137bcc15 CNTV2MacDriverInterface::ReadRegister(unsigned int, unsigned int*, unsigned int, unsigned int) + 203
    1 com.aja.kona.muxer 0x137baace CNTV2MacDriverInterface::GetOutputTimecodeOffset(unsigned int*) + 48
    2 com.aja.kona.muxer 0x137e8551 APW::Mux::Alpine::Muxer::GetOutputTimecodeRegs(unsigned long*, unsigned long*, bool*) + 35
    3 com.aja.kona.uncomp_codec 0x036ca114 getCodecOptionsFromDriver(CodecGlobals*) + 60
    4 com.aja.kona.uncomp_codec 0x036ca33f SWCodecOpen(CodecGlobals*, ComponentInstanceRecord*) + 431
    5 …ple.CoreServices.CarbonCore 0x97d9c014 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    6 com.aja.kona.uncomp_codec 0x036cad4c SWCodecComponentDispatch + 136
    7 …ple.CoreServices.CarbonCore 0x97d94781 CallComponentDispatch + 29
    8 …ple.CoreServices.CarbonCore 0x97d94762 CallComponentOpen + 43
    9 …ple.CoreServices.CarbonCore 0x97d92a30 OpenAComponent + 433
    10 com.apple.QuickTime 0x98bc273d insertPossibleChainsUsingPreDecompress + 4313
    11 com.apple.QuickTime 0x98bbfd21 insertPossibleChainsUsingCodec + 196
    12 com.apple.QuickTime 0x98bbfae0 insertPossibleChains + 136
    13 com.apple.QuickTime 0x98bbdc68 FindBestChain + 1571
    14 com.apple.QuickTime 0x98bbc218 ICMSequenceGetChain + 392
    15 com.apple.QuickTime 0x98bb53ea DoBandedDecompress + 5677
    16 com.apple.QuickTime 0x98bb3bc1 ICMAction + 1177
    17 com.apple.QuickTime 0x98bb27d0 ICMDeviceLoop + 546
    18 com.apple.QuickTime 0x98bbb75e DecompressSequenceFrameWhen + 714
    19 com.apple.color 0x001dfea9 libmac_deviceOutput::writeContext(unsigned char) + 3545
    20 com.apple.color 0x0028f059 ft_frameviewer::drawClipWithCdl(sui_display*, ft_clip*, ft_cdl*, unsigned char) + 1657
    21 com.apple.color 0x0028f410 ft_frameviewer::draw(sui_display*) + 224
    22 com.apple.color 0x0024a6f0 sui_panel::basicDraw(sui_display*) + 400
    23 com.apple.color 0x00241486 sui_layer::draw(sui_display*) + 214
    24 com.apple.color 0x00237ebc sui_display::draw() + 732
    25 com.apple.color 0x0021f5f6 sui::displayFunc(int) + 294
    26 com.apple.color 0x00247bda sui_multitask::refreshCallback(int) + 26
    27 com.apple.color 0x001d9a61 libmac_refreshAllPorts() + 81
    28 com.apple.color 0x002481e0 sui_multitask::taskEvents() + 112
    29 com.apple.color 0x001db651 libmac_mouseEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3025
    30 com.apple.HIToolbox 0x9887ec2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
    31 com.apple.HIToolbox 0x9887def6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    32 com.apple.HIToolbox 0x988a07f3 SendEventToEventTarget + 52
    33 com.apple.HIToolbox 0x988b234f ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
    34 com.apple.HIToolbox 0x9887f080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
    35 com.apple.HIToolbox 0x9887def6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    36 com.apple.HIToolbox 0x988a07f3 SendEventToEventTarget + 52
    37 com.apple.HIToolbox 0x98a29c17 ToolboxEventDispatcher + 86
    38 com.apple.HIToolbox 0x98a29d4f RunApplicationEventLoop + 243
    39 com.apple.color 0x0000a675 main + 3093
    40 com.apple.color 0x00003596 start + 54
    Thread 1: Dispatch queue: com.apple.libdispatch-manager
    0 libSystem.B.dylib 0x96d4b922 kevent + 10
    1 libSystem.B.dylib 0x96d4c03c _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x96d4b4f9 _dispatch_queue_invoke + 163
    3 libSystem.B.dylib 0x96d4b29e _dispatch_worker_thread2 + 240
    4 libSystem.B.dylib 0x96d4ad21 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x96d4ab66 start_wqthread + 30
    Thread 2:
    0 libSystem.B.dylib 0x96d4a9b2 __workq_kernreturn + 10
    1 libSystem.B.dylib 0x96d4af48 _pthread_wqthread + 941
    2 libSystem.B.dylib 0x96d4ab66 start_wqthread + 30
    Thread 3: com.apple.CFSocket.private
    0 libSystem.B.dylib 0x96d44066 select$DARWIN_EXTSN + 10
    1 com.apple.CoreFoundation 0x91652c83 __CFSocketManager + 1091
    2 libSystem.B.dylib 0x96d527fd _pthread_start + 345
    3 libSystem.B.dylib 0x96d52682 thread_start + 34
    Thread 4:
    0 libSystem.B.dylib 0x96d2509a mach_msg_trap + 10
    1 libSystem.B.dylib 0x96d25807 mach_msg + 68
    2 com.apple.CoreFoundation 0x9161337f __CFRunLoopRun + 2079
    3 com.apple.CoreFoundation 0x91612464 CFRunLoopRunSpecific + 452
    4 com.apple.CoreFoundation 0x916183a4 CFRunLoopRun + 84
    5 com.apple.DVCPROHDMuxer 0x11f9398f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
    6 libSystem.B.dylib 0x96d527fd _pthread_start + 345
    7 libSystem.B.dylib 0x96d52682 thread_start + 34
    Thread 5:
    4 com.apple.CoreFoundation 0x91612291 CFRunLoopRunInMode + 97
    5 com.apple.Foundation 0x969526f4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
    6 com.apple.Foundation 0x96919ad0 -[NSThread main] + 45
    7 com.apple.Foundation 0x96919a80 __NSThread__main__ + 1499
    8 libSystem.B.dylib 0x96d527fd _pthread_start + 345
    9 libSystem.B.dylib 0x96d52682 thread_start + 34
    Thread 6:
    0 libSystem.B.dylib 0x96d250fa semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x96d52c85 _pthread_cond_wait + 1066
    2 libSystem.B.dylib 0x96d81aa8 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x97d73e3d TSWaitOnConditionTimedRelative + 242
    4 …ple.CoreServices.CarbonCore 0x97d73b7b TSWaitOnSemaphoreCommon + 511
    5 …ickTimeComponents.component 0x9499b591 ReadSchedulerThreadEntryPoint + 4698
    Thread 7:
    5 …ple.CoreServices.CarbonCore 0x97dce6ee AIOFileThread(void*) + 1127
    Thread 8:
    3 com.aja.kona.muxer 0x137b0316 APW::PTA::Synchronizable::Wait(long long) + 162
    4 com.aja.kona.muxer 0x137e89ef APW::Mux::Alpine::Muxer::PlaybackAutoCirculateSleep(long long) + 55
    5 com.aja.kona.muxer 0x137ea1f9 APW::Mux::Alpine::Muxer::RunPlaybackAutoCirculateThread() + 1779
    6 com.aja.kona.muxer 0x137e8abb APW::Mux::Alpine::Muxer::Run(int) + 107
    7 com.aja.kona.muxer 0x137b0449 APW::PTA::Thread::RunHelper(void*) + 27
    Thread 9:
    2 com.apple.framework.IOKit 0x9815e46d io_connect_method + 574
    3 com.apple.framework.IOKit 0x9810ebae IOConnectCallMethod + 318
    4 com.apple.framework.IOKit 0x9810edf6 IOConnectCallScalarMethod + 84
    5 com.aja.kona.muxer 0x137bca28 CNTV2MacDriverInterface::WaitForInterrupt(_INTERRUPT_ENUMS_, unsigned int) + 148
    6 com.aja.kona.muxer 0x137ce673 CNTV2Card::WaitForFieldID(NTV2FieldID) + 35
    7 com.aja.kona.muxer 0x137ec6a8 APW::Mux::Alpine::Muxer::RunPlaybackVbiThread() + 1904
    8 com.aja.kona.muxer 0x137e8aa3 APW::Mux::Alpine::Muxer::Run(int) + 83
    9 com.aja.kona.muxer 0x137b0449 APW::PTA::Thread::RunHelper(void*) + 27
    10 libSystem.B.dylib 0x96d527fd _pthread_start + 345
    11 libSystem.B.dylib 0x96d52682 thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0x137bcb57 ecx: 0x4b6f6e58 edx: 0x00000000
    edi: 0x01d18600 esi: 0x020bb510 ebp: 0xbfff2a48 esp: 0xbfff2a00
    ss: 0x0000001f efl: 0x00010286 eip: 0x137bcc15 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x4b6f6e58
    Binary Images:
    0x1000 – 0x3bbff7 com.apple.color 1.5.3 (596) <8255BE8E-547F-4D2E-B0EC-60031163F4D6> /Applications/Color.app/Contents/MacOS/Color
    0x5b0000 – 0x6acfef +com.red.redcode.color 4.2 (4.2) <55188FCE-40D6-7155-3762-7C1CC348AD96> /Library/Frameworks/REDCODE.Color.framework/Versions/A/REDCODE.Color
    0x6cf000 – 0x6d6fff com.apple.AEProfiling 1.2 (22) <43A46C32-8E13-82DD-8AF1-2A40690BF810> /Applications/Color.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x6e0000 – 0x6effff com.apple.AERegistration 1.2 (77) <5D18C47F-6F9E-0C4C-8875-24A14A97186D> /Applications/Color.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x703000 – 0x70cff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x714000 – 0x732fef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    0x741000 – 0x74cfff com.apple.color.controlSurfaces.framework 1.0 (2) <5FDAB3A5-633C-C2F2-2374-F1E7039165F7> /Applications/Color.app/Contents/Frameworks/ColorControlSurfaces.framework/Versions/A/ColorControlSurfaces
    0x757000 – 0x97dfe7 com.apple.prokit 6.0.2 (1177) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0xa81000 – 0xb36fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) /usr/lib/libcrypto.0.9.7.dylib
    0x2ef1000 – 0x2ef3ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x3513000 – 0x3577fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    0x3597000 – 0x35ddffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x35e3000 – 0x35e5ff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
    0x35eb000 – 0x3688ff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0x36c8000 – 0x36e7fe2 +com.aja.kona.uncomp_codec 4.0 (4.0) /Library/QuickTime/AJAUncompressedCodec.component/Contents/MacOS/AJAUncompressedCodec
    0x374f000 – 0x3773fe7 GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x37d4000 – 0x37dcff7 com.apple.proapps.mrcheckpro 1.4 (398) <400C6D0F-2AC3-F06D-E20C-741BA3D9A558> /Applications/Color.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0xe7cd000 – 0xe7d1ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <474B24B9-8CAE-D35D-7A5A-D07CFF58F349> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0xe7d6000 – 0xe7d6ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0xe7eb000 – 0xe7f6ff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <738D36A7-8DBD-3BD7-CD35-4B171397782C> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x11f7c000 – 0x11fe1fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x12800000 – 0x12978fe7 GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x129aa000 – 0x12daffe7 libclh.dylib 3.1.1 C (3.1.1) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x13547000 – 0x13588fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x1358f000 – 0x13595ffb com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <41652FA7-74E5-B934-3E04-B3F89D80ABF3> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x1359a000 – 0x135effe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x1360e000 – 0x1364afe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1756.15) <9C48FD18-B6B8-10FA-3B09-47915626A73C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0x13656000 – 0x13713fe2 com.apple.DesktopVideoOut 1.2.7 (1.2.7) <54E0C747-1169-FB4A-2CB4-9EA9BD5398F8> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x13732000 – 0x13779fe7 +com.aja.kona.videooutput 8.1.2 (8.1.2) <549C115C-8F82-16CF-42AB-8D1E3E300D4D> /Library/QuickTime/AJAVideoOutput.component/Contents/MacOS/AJAVideoOutput
    0x13797000 – 0x137a8fe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x137af000 – 0x13830feb +com.aja.kona.muxer 8.1.2 (8.1.2) /Library/QuickTime/AJAMuxer.component/Contents/MacOS/AJAMuxer
    0x138a9000 – 0x138abff3 +com.aja.kona.videooutputclock 8.1.2 (8.1.2) /Library/QuickTime/AJAVideoOutputClock.component/Contents/MacOS/AJAVideoOutputClock
    0x138af000 – 0x138bbfff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (195) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
    0x138c3000 – 0x138cdff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x13a6d000 – 0x13aa0feb +com.aja.kona.videooutputcodec 8.1.2 (8.1.2) /Library/QuickTime/AJAVideoOutputCodec.component/Contents/MacOS/AJAVideoOutputCodec
    0x13aba000 – 0x13b27fe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0x13b74000 – 0x13f59fe3 QuickTimeH264.scalar ??? (???) <275FEF5D-B116-979D-9637-CDCEE2DDC820> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0x13fb5000 – 0x13fecfe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x13ffc000 – 0x140abfe3 com.apple.AppleHDVCodec 1.6 (229) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x140d3000 – 0x140eefef com.apple.AppleIntermediateCodec 1.3.2 (153) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0x140f4000 – 0x14107fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x14119000 – 0x14132fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x14137000 – 0x14156fe2 +com.aja.kona.codec 4.0 (4.0) /Library/QuickTime/AJACodec.component/Contents/MacOS/AJACodec
    0x1416a000 – 0x1418eff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0x14199000 – 0x1419bff7 com.apple.PDFImporter 2.1 (???) /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
    0x141a1000 – 0x142a1feb +com.red.redcode.quicktime 4.2 (4.2) /Library/QuickTime/REDCODE.QT.component/Contents/MacOS/REDCODE.QT
    0x143a7000 – 0x143b4ffb +net.telestream.license 1.0.7.2-GC (1.0.7.2-GC) <3B3ADB81-79F3-6371-31FE-66EF8D8E3100> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0x17303000 – 0x174f5fe2 +net.telestream.wmv.import 2.3.5.4 (2.3.5.4) <7DAE8093-C4E1-4719-A095-5FC766307082> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x1752a000 – 0x176ebff2 +net.telestream.wmv.advanced 2.3.5.4 (2.3.5.4) <33F5D738-1D6C-7F92-CEC2-07BDE4D151A1> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x1772f000 – 0x177a9fef com.apple.AppleVAH264HW.component 2.0 (1.0) <6DA1BA82-A66D-6098-7989-965ADF1E9C7C> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    0x70000000 – 0x700cbfff com.apple.audio.units.Components 1.6.4 (1.6.4) <67DA329D-A571-6066-953C-4BBFCBF87BD5> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8f0c4000 – 0x8f80cff3 com.apple.GeForceGLDriver 1.6.23 (6.2.3) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
    0x90003000 – 0x9013aff7 com.apple.CoreAUC 6.04.05 (6.04.05) <4A2BEE1A-A74A-746B-EFA6-470CD3354252> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x9013b000 – 0x90219fef com.apple.QuickTimeMPEG4.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9021f000 – 0x90275ff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x902b2000 – 0x9035ffe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
    0x90360000 – 0x90372ff7 com.apple.CoreMediaAuthoring 0.706 (706) <81D68084-D7BD-E52E-9B1C-C8EC0FCECE3C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x90550000 – 0x90651fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
    0x9067c000 – 0x9087aff3 com.apple.JavaScriptCore 6533.20 (6533.20.20) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x9087b000 – 0x9088dff7 com.apple.MultitouchSupport.framework 207.10 (207.10) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x9088e000 – 0x90929ff7 com.apple.ApplicationServices.ATS 275.15.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x9092a000 – 0x9095bff7 libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x9095c000 – 0x909d3ff3 com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x909d4000 – 0x909e2ff7 com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x90a31000 – 0x90a3bfe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x90a3c000 – 0x90b78ff7 com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x90b80000 – 0x90c00feb com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x90c01000 – 0x90c03ff7 com.apple.QuickTimeH264.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x90ce1000 – 0x90cedff7 libkxld.dylib ??? (???) <585F0A91-EFB8-E066-BDFB-4AFF37A8C323> /usr/lib/system/libkxld.dylib
    0x90cee000 – 0x90ceeff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x90d1a000 – 0x90d4aff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x90d4b000 – 0x90d66ff7 libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x90d80000 – 0x9156f557 com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x91570000 – 0x91577ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <37255DC6-9FD1-45CC-AC80-A84FD2B5450A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x915c1000 – 0x915d5fe7 libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
    0x915d6000 – 0x91751fe7 com.apple.CoreFoundation 6.6.4 (550.42) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x91752000 – 0x91778ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x91785000 – 0x917e9ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x917ea000 – 0x917ebff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x917ec000 – 0x917f3ff7 com.apple.iChat.IMUtils 5.0.5 (747) <165000D5-219A-DFAE-68C6-25F6ED12A00B> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
    0x917f4000 – 0x91c2bff3 com.apple.RawCamera.bundle 3.6.4 (561) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x91c2c000 – 0x91c37ff7 libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x91c40000 – 0x91c90ff7 com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x91c91000 – 0x920a7ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x920a8000 – 0x920c7ff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x920c8000 – 0x920c9ff7 com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x920ca000 – 0x920d1ff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x920d2000 – 0x92507ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92508000 – 0x92577ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x92578000 – 0x925bbff7 libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x925bc000 – 0x925bffe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x925ec000 – 0x92632ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
    0x92633000 – 0x92644ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x92645000 – 0x926e2fe3 com.apple.LaunchServices 362.2 (362.2) <77B97C8B-321D-46A2-1DB5-388E45DFBC9F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x926e3000 – 0x92744fe7 com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x92745000 – 0x927b3ff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x927b4000 – 0x928f7fef com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x928f8000 – 0x929a6ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x929a7000 – 0x929ddfff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
    0x92a2f000 – 0x92c94feb com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x92c95000 – 0x92ccefe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x92ccf000 – 0x92cf3ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x93085000 – 0x93085ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x93127000 – 0x93233ff7 libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x932a4000 – 0x933a8fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
    0x933a9000 – 0x93462fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
    0x934de000 – 0x934e9ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x934ea000 – 0x934f0fe7 com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x93518000 – 0x93540ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
    0x94166000 – 0x94166ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x94167000 – 0x941b4feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x941b5000 – 0x9425ffe7 com.apple.CFNetwork 454.11.12 (454.11.12) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x94260000 – 0x942a0ff3 com.apple.securityinterface 4.0.1 (40418) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x942a1000 – 0x942f2ff7 com.apple.HIServices 1.8.2 (???) <63B29FF5-7077-8317-E710-2D94ADF7B499> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x942f3000 – 0x942fbff7 com.apple.DisplayServicesFW 2.3.0 (283) <3FF74427-2240-9E23-876D-9A9CDAF62114> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x9430c000 – 0x9431afe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
    0x943e3000 – 0x95336fe3 com.apple.QuickTimeComponents.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x95337000 – 0x95357fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) /usr/lib/libresolv.9.dylib
    0x95358000 – 0x95358ff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x95359000 – 0x953d3fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x953e7000 – 0x953e7ff7 com.apple.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x953e8000 – 0x9542aff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x954e7000 – 0x955b2fef com.apple.CoreServices.OSServices 359 (359) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x955ec000 – 0x9562fff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x95630000 – 0x9563bff7 com.apple.CrashReporterSupport 10.6.7 (258) <71CC59D1-E197-7431-5973-2C079A749257> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x95650000 – 0x9572affb com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x9572b000 – 0x9572bff7 com.apple.Carbon 150 (152) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x9576f000 – 0x957d9fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x9580d000 – 0x95cc6ffb com.apple.VideoToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x95ccc000 – 0x95d0aff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x95d0b000 – 0x95d15ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x95d16000 – 0x95daefe7 edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x95ddc000 – 0x95de0ff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x95dfa000 – 0x95fdcfff com.apple.imageKit 2.0.3 (1.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x95fdd000 – 0x96037fe7 com.apple.CorePDF 1.3 (1.3) /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x96038000 – 0x96164ffb com.apple.MediaToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x96165000 – 0x96165ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x96166000 – 0x9619eff7 com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x961a6000 – 0x962a8fef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x963b9000 – 0x96724ff7 com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x96725000 – 0x9673dff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x9673e000 – 0x967e6ffb com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x967e7000 – 0x967fbffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x96903000 – 0x96b76fe7 com.apple.Foundation 6.6.6 (751.53) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x96b77000 – 0x96b80ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x96b81000 – 0x96bc8ffb com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x96bc9000 – 0x96bd6fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) /usr/lib/libbz2.1.0.dylib
    0x96bd7000 – 0x96bfeff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x96c24000 – 0x96cb6fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x96cb7000 – 0x96cf0ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
    0x96d24000 – 0x96ecbff7 libSystem.B.dylib 125.2.10 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
    0x96ecc000 – 0x96ecfff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x96ed0000 – 0x96ee0ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
    0x96f01000 – 0x96f7cfff com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x96f7d000 – 0x970fffe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
    0x97100000 – 0x9713dff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x972a3000 – 0x972a3ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x972a4000 – 0x972e4ff7 com.apple.ImageCaptureCore 1.0.4 (1.0.4) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x972e5000 – 0x9732efe7 libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x9732f000 – 0x9734dff7 com.apple.iChat.IMFoundation 5.0.5 (747) <4F6827AF-F713-A8F8-92E8-C9EC59D92416> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x9734e000 – 0x97352ff7 libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x97353000 – 0x973abfe7 com.apple.datadetectorscore 2.0 (80.7) <18C2FB6A-BF60-F838-768C-0306151C21DA> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x973ac000 – 0x9742effb SecurityFoundation ??? (???) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x9742f000 – 0x97473fe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x97474000 – 0x9762efeb com.apple.ImageIO.framework 3.0.4 (3.0.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9762f000 – 0x9762fff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x97630000 – 0x97671ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x97672000 – 0x9789dff3 com.apple.QuartzComposer 4.2 ({156.28}) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x978df000 – 0x979d3ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
    0x979d4000 – 0x979f0fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x979f1000 – 0x979f6ff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x979f7000 – 0x979faffb com.apple.help 1.3.1 (41) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x979fb000 – 0x97a32fe7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
    0x97a33000 – 0x97a70ff7 com.apple.CoreMedia 0.484.20 (484.20) /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x97a71000 – 0x97b42fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x97b43000 – 0x97b87ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x97bce000 – 0x97c01ff3 libTrueTypeScaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x97c02000 – 0x97c7bff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x97d2d000 – 0x9804dff3 com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x9804e000 – 0x9804fff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x98050000 – 0x98083ff7 com.apple.AE 496.4 (496.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x9808c000 – 0x980c7feb libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x980c8000 – 0x980eafef com.apple.DirectoryService.Framework 3.6 (621.11) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x980eb000 – 0x980fbff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x980fc000 – 0x98109ff7 com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x9810a000 – 0x98167ff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x98168000 – 0x98175ff7 com.apple.AppleFSCompression 24.4 (1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x9826f000 – 0x98284fff com.apple.ImageCapture 6.0.2 (6.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x98285000 – 0x98341fff com.apple.ColorSync 4.6.6 (4.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x98342000 – 0x98382fe7 com.apple.IMCore 5.0.5 (747) <625F3A2B-3E43-2BD2-99C0-58E1C1765F65> /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
    0x98383000 – 0x98385ff7 com.apple.securityhi 4.0 (36638) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x98386000 – 0x98562fe7 libType1Scaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
    0x98563000 – 0x98567ff7 libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x98568000 – 0x98648fe7 com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x98649000 – 0x9866afe7 com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x9866b000 – 0x98872feb com.apple.AddressBook.framework 5.0.4 (883) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x98873000 – 0x98876ff7 libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x98877000 – 0x98b9bfef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x98b9c000 – 0x98ba2fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x98ba3000 – 0x98ba5ff7 libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x98ba6000 – 0x98e9ffef com.apple.QuickTime 7.6.6 (1756.15) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x98fee000 – 0x9911cfe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9911d000 – 0x99132ff7 com.apple.iChat.InstantMessage 5.0.5 (747) <4E1D077E-3733-5565-ADB9-C9B2C3EC89BE> /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
    0x99133000 – 0x99a13ff7 com.apple.AppKit 6.6.7 (1038.35) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x99a14000 – 0x99acaffb libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0xffff0000 – 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    Model: MacPro4,1, BootROM MP41.0081.B08, 4 processors, Quad-Core Intel Xeon, 2.66 GHz, 3 GB, SMC 1.39f5
    Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
    Memory Module: global_name
    Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: pci-bridge, sppci_pci2pcibridge, Slot-3
    PCI Card: pcif1d0,c0fe, sppci_video, Slot-3@5,12,0
    PCI Card: NVIDIA GeForce GT 120, Display, Slot-1
    Serial ATA Device: HL-DT-ST DVD-RW GH41N
    Serial ATA Device: Hitachi HDE721064SLA360, 596.17 GB
    USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1006, 0xfd100000
    USB Device: Apple Optical USB Mouse, 0x05ac (Apple Inc.), 0x0304, 0xfd130000
    USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0220, 0xfd120000
    USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000
    USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x5a110000
    FireWire Device: Rugged FW/USB, LaCie, Up to 800 Mb/sec
    FireWire Device: built-in_hub, Up to 800 Mb/sec
    Aja Sales department replied 15 years, 4 months ago 3 Members · 2 Replies
  • Gary Adcock
    May 13, 2011 at 3:43 pm
    [Nicolas Ayerbe]
    “0 com.aja.kona.muxer 0x137bcc15 CNTV2MacDriverInterface::ReadRegister(unsigned int, unsigned int*, unsigned int, unsigned int) + 203
    1 com.aja.kona.muxer 0x137baace CNTV2MacDriverInterface::GetOutputTimecodeOffset(unsigned int*) + 48”
    my guess is the Wrong Driver or lack of updated kona firmware. You need to make sure the firmware on the card is updated and that is a manual process on all of the older Kona cards.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Aja Sales department
    May 13, 2011 at 9:20 pm
    You may want to contact AJA Technical Support for assistance with your configuration. You can contact them free of charge via phone or email from 9am to 5pm PST.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
