Activity › Forums › AJA Video Systems › Kona LH causing random shutdowns of G5
  • Kona LH causing random shutdowns of G5
    Posted by David Garcia on March 2, 2006 at 2:59 pm
    Hi. I just installed a new Kona LH card into a Dual 2ghz G5 with 8gigs of RAM and and an ATI 128MB gfx card running two 23 inch monitors. Latest FCP 5 and Latest OSX and quicktime updates.
    The card seems to be working great, however I will walk away from the machine and come back to find it has crashed. The last time it happened, It would not restart and I had to unplug the machine for 20 minutes before it would start up again.
    I ran the AJA conflict catcher before install. Nothing came up.
    Any thoughts or help would be appreciated.
    David
    david garcia
    Halflife* Digital
    albuquerque, nm
    Jeff Bernstein replied 20 years, 6 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    March 2, 2006 at 3:29 pm
    Sleep plays havoc with FCP running. Is that what’s going on? You can sleep the monitors, but you can’t sleep the drives very well it seems.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    March 2, 2006 at 5:04 pm
    Jerry’s on to something. Go into your energy saver preferences and turn your processors to highest and tell your computer to never sleep and turn off screen savers too. The only thing I leave on is to sleep my monitors off after 2 hours, which rarely happens anyway.
  • Jeff Bernstein
    March 6, 2006 at 5:57 pm
    Does it crash with a Kernal Panic or does it just lock up?
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
