Activity Forums AJA Video Systems Kona LH Audio Issues
  • Kona LH Audio Issues
    Posted by David on December 16, 2005 at 4:46 am
    I’ve just upgraded my system from CineWave to Kona LH and I’m having some issues with audio… The G5 is setup to use Kona for all audio. Initially, after installation, Every sound played through the Mac had a 1 second echo. There seemed to be some buzzing with this. In Final Cut… whenever you stopped the sequence, the audio continued (echoed?) for one second after, again with the popping. I spoke to AJA, and they said there may be an issue with “cache playback” or something like that, but didn’t offer a solution. They suggested I speak with Apple, and mentioned that I might need a firmware upgrade. Disappointing…
    I now have a new problem… no audio at all from the desktop or Final Cut, except when I attempt to capture. I can hear the audio from the source, but there is no indication that FCP sees it. Preview (FCP 5) shows no levels. When source is captured, there is no audio.
    Is there something in the initial setup that I am missing? Since this is an issue that initially was present on the desktop as well as FCP, I am assuming it to be a Kona problem. Is there something in FCP that is set wrong? I’m open to any suggestions…
    Logan Kelsey replied 20 years, 9 months ago 3 Members · 4 Replies
  • David Smith
    December 16, 2005 at 5:56 am
    This thread from just a few days ago might be relevent to the “echo” problem:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=857456&forumid=98&postid=857456&pview=t
    Have you double checked audio input settings in the Kona software and your system prefs?
    Regards,
    David
  • Logan Kelsey
    December 16, 2005 at 6:58 pm
    [D Phillips] “Is there something in the initial setup that I am missing? Since this is an issue that initially was present on the desktop as well as FCP, I am assuming it to be a Kona problem. Is there something in FCP that is set wrong? I’m open to any suggestions…”
    I’ve used the KONA2_Audio_FAQ.pdf as a referance for set-up:
    Set Output Volume slider to 67% for Unity gain
    In FCP Log and Capture dialog, this translates to
  • David
    December 16, 2005 at 11:34 pm
    Saw that… I now have Kona only do FCP.
    > I got some of the problems worked out… had to have a
    > firmware upgrade which I found on the Apple support
    > website, but paid Apple $50 to verify. G5 Firmware
    > upgrade 5.1.4 in case anyone asks in the future.
    > Stopped the cache “echo” and popping.
    > Thanks for helping.
    > Dave Phillips
  • Logan Kelsey
    December 19, 2005 at 7:10 pm
    [D Phillips] “upgrade 5.1.4 in case anyone asks in the future.”
    Just did the firmware upgrade (first gen G5 2.0) and my audio problems are gone.
    Cheers,
    Logan
    Vertical Online
    https://www.verticalonline.com
