Kona LH and XDCAM HD monitoring
i posted this in the FCP forum by mistake. It is probably more applicable here.
so it looks like we are going to go with XDCAM HD as our new aquisition format.
it all looks and sounds great. just a few post questions for those using the format.
how are you monitoring your edits…i assume that as it’s Mpeg Long GOP, FCP can’t output to my broadcast monitor as per the limitations it has with HDV?
using an AJA Kona LH will that allow me the downconverted HD signal to my SD monitor?G5 DP 2.0 (Power PC)
4.0G RAM
OS 10.4.8
QT 7.1.3
FCP 5.1.2
BMD Decklink Extreme 5.9
PAL Land
