Activity › Forums › Apple Final Cut Pro Legacy › Kona LH and Drop Frame
Posted by Buck Miller on January 26, 2007 at 4:17 amI am trying to import some Beta SP footage through my Kona LH that was recorded as drop frame. When I try to capture the footage, it “kicks out” about a minute into the capture whether I am batching or capturing “now”. I spoke with AJA, they said they thought it was an Apple/FCP setting, but in the capture settings box, the drop/non-drop choice is greyed out, and therefore, cannot be chosen. I had no problem capturing non-drop footage. Any ideas? Thanks!
Buck Miller replied 19 years, 7 months ago 4 Members · 7 Replies -
Shane Ross
January 26, 2007 at 4:35 am -
Buck Miller
January 26, 2007 at 5:45 amThanks guys.
Jeremy, I am using the Xserve RAID drives.Shane, in the “Capture Presets” tab of the “Audio/Video Settings”:
The Preset is: AJA Kona LH: 525 29.97 10 Bit
When I click on Edit:
Frame Size: 720 x 486 CCIR 601 NTSC (40:27)QuickTime Video Settings:
Digitizer: AJA Kona 10-bit Digitizer
Input: 525i29.97 (720×486)
Compressor: Uncompressed 10-bit 4:2:2
Quality: 100%
FPS: 29.97Quicktime Audio Settings:
Device: AJA Kona
Input: (grayed out)
Format: 48.000 kHz 24-bit 8-chanCapture Card Supports Simultaneous Play Through and Capture IS checked
Remove Advanced Pulldown and/or Duplicate Frames from FireWire sources IS NOT checked
Hight-Quality Video Play Through IS checkedUnder the “Device Control Presets” tab (I use a Sony 1800):
The Preset is AJA Kona LH NTSC Sony VTR
Protocol: Sony RS0422
Audio Mapping: 2 channels
Time Source: LTC+VITC
Port: Kona Serial
Frame Rate: 29,97
Default Timecode: THIS IS GRAYED OUT!Use Deck Search Mechanism IS checked
Capture Offset: -2
Handle Size: 00:00:00;00
Playback Offset: 00:00;00Hope this helps. Thanks!
David Roth weiss
January 26, 2007 at 6:30 pmAre you trying to capture from the very head of the reel or from the very beginning of a camera start?
The only time I ever see any drop frame/non-drop issues is when not allowing the deck enough preroll time to accurately set the proper timecode flavor. This can apply to either a logged entry or with record now.
DRW
Buck Miller
January 26, 2007 at 6:44 pmThanks David. No, I am not trying to start at the beginning of the tape. It is really about in the middle. I can capture a minute at a time, and edit that together, but as you can imagine, that will take some time with three 30 minute tapes to do. I am not SURE that drop frame is the issue, I just assume it is because all other tapes have been non-drop and I have been able to capture them fine.
Buck
David Roth weiss
January 26, 2007 at 6:55 pm[bucksbucks] “I am not SURE that drop frame is the issue, I just assume it is because all other tapes have been non-drop and I have been able to capture them fine.”
Drop/non-drop is pretty much a non-issue. I would instead consider one of three things as a more likely candidate:
1) corrupt timecode on the tape – in this case dub to another tape
2) trash prefs and try again – prefs got corrupted in between tapes
3) project developed corruption – try capturing the offending tape to a new project
Hope this helps…
DRW
Buck Miller
January 26, 2007 at 7:24 pmIt will be tonight, but I will try all of these things. Great ideas. I will let you know if any of these work. Thanks again.
Buck
