Activity › Forums › AJA Video Systems › KONA LH and Convergent Design
  • Bob Zelin
    February 2, 2006 at 12:07 am
    no one has to do this. The HDV VTR has analog HD outputs (Y Pb Pr), and this goes right into the analog component inputs of the Kona LHe, which will take in analog HD signals, as well as analog standard def component.
    See – look how much money you just saved !
    bob Zelin
  • Lou Squitieri
    February 2, 2006 at 3:16 am
    Hi Bob,
    Yes, I tried the component out on my Z1, and,,, I think the video looks a liitle soft, and there was quite a bit of color shift. I also looked at the sony deck HVR-10MU, and it looks like it has same component cables as the Z1. I am not sure where the bottle neck in the system is. I like the idea of converting from firewire to Convergent Design HD-SDI, thereby keeping it all digital. But, like you said..$$$
    Lou
  • Kevin Wild
    February 3, 2006 at 7:15 am
    And don’t forget that the Convergent HD-Connect takes the timecode from the firewire stream and gives you a RS422 connection. Biggest reason to get this box…imo.
    Kevin
