Kona LH analogue monitoring
We’ve got a couple of Mac Pros with Kona LH cards installed which are being used with Picture Ready for capture of live footage.
The incoming material has 4 channels of embedded audio and we need to monitor either tracks 1 & 2 or 3 & 4. The only connectors on the breakout cable of the Kona card are analogue A1 & A2. I see that within the AJA control panel you can select the audio monitoring from the analogue out section but this does not seem to affect the output through these analogue XLRs.
So does anybody have an idea how this can be done… should we be able to select which of the 4 channels is fed to the XLRs or do we need to use a separate breakout box to achieve this? The problem I have is that we’re setting this up for the World Cup and therefore need to resolve this quite quickly.
Brian
