Activity › Forums › AJA Video Systems › Kona downconvert monitoring, field order issues.
  • Kona downconvert monitoring, field order issues.
    Posted by Craig Meadows on November 12, 2005 at 3:58 pm
    Successfully captured Z1U 50i pal hdv via hd analog outs and Aja HD10a converter to a 1080/50i dvcproHD PAL sequence in FCP5.
    Final project is for NTSC but experimenting with 50i/25 for the frame rate.
    1080i/50 hd PAL plays back fine on our sony L series monitor which is auto ntsc/pal. Coming from k-box component analog outs. FCP Easy setup 1080i/50 dvcproHD.
    Then switch the Kona to down convert to 625i for monitoring, playback is fine.
    Use Nattress Standards Converter to convert originally captured hd pal clip to hd ntsc…works great… 1080i/60 ntsc hd plays back fine on monitor.
    Then switch the Kona to down convert to 525i…this is where the sony monitor freaks…footage is very jumpy, like a field order issue.
    HDV 1080 pal or ntsc is upper field right? Which I am not capturing but just curious.
    DVCPro100 HD PAL is also upper field?
    DVCPro 100 HD NTSC is what???
    Thanks so much!
    Steve Covello replied 20 years, 10 months ago 2 Members · 1 Reply
  • Steve Covello
    November 13, 2005 at 4:11 pm
    This was taken from the Algolith website knowledge base:
    For NTSC footage the field dominance is “Lower or Odd Field First “, for all HD formats and PAL, the field dominance is “Upper or Even Field First “.
    https://support.algolith.com/index.php?x=&mod_id=2&id=7
    Algolith makes software based standards/format conversion products.
    The exception to the above statement is the old ABVB Avids — the ones that were AVR77 versus the Meridien 1:1 — which were Upper Field dominant, but no one has those much anymore.
    Check out this link and goto the HD/ECinema link. Many good documents on workflow and tech.
    https://www.cinematography.net/
    steve covello
    double wide post
